'06 Hemi Oil Filter Access on a 1500 4x4
Old Aug 19, 2007 | 08:41 PM
tarponhead's Avatar
tarponhead
Default '06 Hemi Oil Filter Access on a 1500 4x4
I just completed my second oil change and everytime I complete this task I curse like a sailor trying to get the oil filter off. Every filter tool I have (wrench, cup type) seems to slip, strip.
Today I wound-up crushing it and then was able to spin it off...W T F!
Any help/hints...Please advise!
Thanks ALL!
Eddie
Old Aug 19, 2007 | 08:46 PM
nastyram's Avatar
nastyram
Default RE: '06 Hemi Oil Filter Access on a 1500 4x4
do you use a wrench when putting it back on?
Old Aug 19, 2007 | 08:57 PM
tarponhead's Avatar
tarponhead
I hand tight the filter and give it just a "Little wrench" just to snug it up, but nothing to crazy. I don't think I over tighting it.....
Old Aug 19, 2007 | 09:29 PM
RailroadMan's Avatar
RailroadMan
Consider using grease on the oilfilter gasket instead of oil. Maybe the Hemi runs hot enough to dry the gasket to the filter mount - and it becomes difficult to remove.
What kind of filter are you using? some have a better quality rubber than others.
Old Aug 19, 2007 | 09:40 PM
07 Ram TRX4's Avatar
07 Ram TRX4
I don't think you should wrench the new filter at all... hand tighten ONLY.... less problems later.... I belive it says that on some of the packages as well....
Old Aug 19, 2007 | 11:59 PM
hemiyellow's Avatar
hemiyellow
DC Insider
go to Sears and buy the oil filter wrench that has like 3 90 degree fingers on it and it goes on a 3/8" ratchet...that will cure your problems of taking it off...and HAND tighten only...never put a wrench on it to tighten it
Old Aug 20, 2007 | 01:01 AM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
The K&N Oil filter has a 1" stamped steel nut welded on the end for a wrench or socket.I love it.Give it a try if you have the clearances. I don't know whatthe 1500 looks like around there.
Like everyone says. Don't over tighten it. Lubricate the gasket with clean engine oil.
Old Aug 23, 2007 | 05:55 PM
tarponhead's Avatar
tarponhead
Thanks for the reply's... When you all state "don't use a wrench when installing the new one".. I'm concerned that the filter would spin loose (from just a hand tighten) from the vibrations.. Should I be???
The filter I used is a Fram "Offroad".
Old Aug 23, 2007 | 06:05 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
ORIGINAL: tarponhead
Don't worry about hand tightening. The pressure from the ooil system keeps it in place. Just hand tighten the filter. Fram is also a cheaper filter and I myself had problem on previous vehicles where it was a bear to get off. Don't know the reason, but once I changed to using K&N filters, I can now loosen with my hands. No more problems..
Old Aug 23, 2007 | 06:15 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i use Wix filters and never have a problem loosenin them up
