Need less exhaust drone. Ideas?
Old Aug 22, 2007 | 02:02 PM
///Matt's Avatar
///Matt
Default Need less exhaust drone. Ideas?
Hey guys...
I've got a '07 4.7 quad cab, short bed. I've replaced the stock muffler with a 18" ( I think, it might be 14") universal Magnaflow. It sounds AWESOME. Unfortunately, It's got too much drone on the freeway.
Any ideas about how to deaden it? Has anyone tried to Dynamat the underside of the bed?
If I were to change to a brand name catback, would it change my drone?
Or maybe there's a specific exhaust that sounds good, but doesn't drone?
Old Aug 22, 2007 | 02:05 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: Need less exhaust drone. Ideas?
Don't see how'd you get the drone with that engine... i would'nt have changed mufflers.. i'd probably just run straight pipes.... Should sound fine... loud... but fine....Now if you told me you had the 2007 5.7... I'd belive you....
Old Aug 22, 2007 | 02:50 PM
HankL's Avatar
HankL
In most factory style mufflers there is a funny looking section inside
called a 'Helmholz Resonator'
that gets rid of the drone.
http://www.howstuffworks.com/muffler3.htm
If you put on a muffler without a Helmholz Resonator
you need to avoid certain tailpipe lengths in the 55 to 75 inch length.
Go shorter (side exit perhaps)
or go longer
or put a resonator in the middle.
The tailpipe length is like a musical instrument
similar to an old fashioned Pipe Organ in a church
or a flute.
Old Aug 22, 2007 | 04:29 PM
cobra2411's Avatar
cobra2411
I've got a flowmaster 40 on mine and I don't have a drone. My 93 Cobra with flowmasters definatly has one, but not the truck. One question that I have is are you running a tailpipe or a dump? If it's a dump, get it out from under the bed. It's a ton louder with a dump under the vehicle.
Old Aug 22, 2007 | 04:49 PM
tracker's Avatar
tracker
I have the sam problem Matt. I just installed a magnaflow system (with 18in muffler) on my 05 hemi and the cabin drone is loud. I know everybody has a different view on loud but i'm wondering if it could have something to do with the system not being clamped down tight enough. I am trying to decide if I should send it to the shop to get checked out (everything tightened down better than I did it) orshould Isend it in to get the 24in muffler. Everything i've learned on this forum about different exhausts tell me that this shouldn't be this loud inside the cabin.
Old Aug 22, 2007 | 06:37 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Listen to an hour of heavy metal as loud as you can and you won't hear the drone...
Old Aug 22, 2007 | 11:04 PM
///Matt's Avatar
///Matt
I only listen to heavy metal. =) loud. With subwoofers.
And I still have lots of drone. =(
I'm going to measure my system, to see if I comply with HankL's remarkably knowledgeable response.
I can't (or rather more like won't) go shorter, since my muffler itself sits just right forward of the axle, so a pre-wheel dump won't happen. But maybe I can go longer, get a Y and spread to a straight out the back dual?
Hmm..
Old Aug 22, 2007 | 11:59 PM
marv02's Avatar
marv02
Ha Ha I end up taking my 20 inch Maganflow off going back to a stock type muffler it no Helmholz in it this Muffler is it nice sound NOT LOUD AT HWY Speeds just right.
Old Aug 23, 2007 | 01:38 AM
chefred112's Avatar
chefred112
big reason i changed from magnadrone to flows...the dreaded drone...
Old Aug 23, 2007 | 01:39 AM
chefred112's Avatar
chefred112
