high beams with fogs
Old Aug 22, 2007 | 09:27 PM
nastyram's Avatar
nastyram
Default high beams with fogs
does anyone know if anyone makes a kit that keeps the fog lights on with the high beams
Old Aug 22, 2007 | 09:34 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: high beams with fogs
here:
https://dodgeforum.com/m_197878/tm.htm
Old Aug 22, 2007 | 10:11 PM
nastyram's Avatar
nastyram
thanks alot hemiyellow
Old Aug 22, 2007 | 10:18 PM
squirtbottle09's Avatar
squirtbottle09
Your lucky. You get to use the jumper wire. Us 06's+ have to buy a britebox. [&:]
Old Aug 22, 2007 | 10:48 PM
nastyram's Avatar
nastyram
for some reason not working,the fog light relay pin is blank on mine,not sure if it should be or not
Old Aug 22, 2007 | 11:01 PM
hemiyellow's Avatar
hemiyellow
DC Insider
look on the underside of the cover to see.....if you have the stock foglights then it should be there unless it was in a different spot back then, but i dunno if it was or not....i dont think it was......
Old Aug 26, 2007 | 12:09 PM
tdmopar59's Avatar
tdmopar59
the only thing i dont like is you cant turn off your fog lights but i guess its worth it
Old Aug 26, 2007 | 03:03 PM
hemiyellow's Avatar
hemiyellow
DC Insider
well i thought about doing the same thing with mine, cept if i do then i'm gonna rig up a switch so that when the high beams are on and i dont want the fog lights on then just flip the switch and you got high beams only....just havent gotten around to doin it yet lol
