4 x 4 at the drag strip?
Old Aug 26, 2007 | 10:55 PM
workingspy's Avatar
workingspy
Default 4 x 4 at the drag strip?
Just wondering what have people think about using 4wd at the strip. I have not tried yet and heard it wont improve my time but I would like more opinions before trying it.
[IMG]local://upfiles/59482/A12A016B1ACB4E0686E8626AD7DACDC3.jpg[/IMG]
Old Aug 26, 2007 | 11:24 PM
squirtbottle09's Avatar
squirtbottle09
Default RE: 4 x 4 at the drag strip?
It is fine to use in 4x4high. It will give you a better jump off the line.
Old Aug 26, 2007 | 11:34 PM
sa1765's Avatar
sa1765
okay, because you asked for opinions and not facts...i'll chime in. it'd be a waste of power to use 4x4 unless you can't control wheel spin. if you had a turbo and built up boost before a launch...then you would want to use it. i think you'd actually take more time in the 1/4 using 4x4 ....then again, that's just an opinion....i've never tried it.
Old Aug 27, 2007 | 12:02 AM
topcop38's Avatar
topcop38
being an ex drag racer i will tell you that some slight wheelspin is good. no wheelspin is an indication that the motor is underpowered for the available traction which will create a slight bog. minimal wheelspin (no smoke, just a slight slip) will allow the engine to rev quicker producing faster ETs.
watch your 60' times. thats where races are won or lost.
Old Aug 27, 2007 | 12:27 PM
workingspy's Avatar
workingspy
My 60' is real good (2.3) and going to get better with the new superchip. So not only am i looking to always improve on that time but I am having most of my problems hiyying a higher topspeed. From what I heard and it makes sense is that you will have less highend speed. I have already experianced that when using O/D off or on.
