Transmission code P0700
Old Aug 28, 2007 | 01:15 AM
CaymanRam's Avatar
CaymanRam
Default Transmission code P0700
Transmission
P0700 Transmission Control System Malfunction
vehicle throws this code. The car shifts from 1st to 3rd at 3000rpms...but it still drives fine. any ideas what it could be? made a sensor?
please let me know
webster.me@gmail.com
Old Aug 28, 2007 | 03:30 PM
2ManyToys's Avatar
2ManyToys
Default RE: Transmission code P0700
I had the same problem with my truck with only 500 miles on the odomenter. It's a computer control module located in the transmission. Take it to the dealer and they will drop the pan, replace the module, and refill the transmission.
Old Aug 28, 2007 | 07:37 PM
Parts/Service's Avatar
Parts/Service
What year/engine size?
Old Aug 29, 2007 | 11:20 AM
CaymanRam's Avatar
CaymanRam
i got a 2004 4.7 ltr
does anyone know the part number for the module?
Old Aug 29, 2007 | 02:09 PM
eltupac's Avatar
eltupac
I'll do what manytoys said. Let the dealer handle it. You should have 7/70, unless you are over the 70.
Old Aug 29, 2007 | 03:47 PM
CaymanRam's Avatar
CaymanRam
I'm not over, but i live in teh cayman islands, and the truck was bought from the states..so the dealer down here doesnt cover any kind of warranty..sucks cause its a 2004 with only 28000miles on it. thats why i would like to get the part# so i can order from the miami dealership, and get it alot cheaper.
Old Aug 29, 2007 | 04:03 PM
eltupac's Avatar
eltupac
sorry, they dont ship over seas. The site I posted.
Try searching for the part and get the number.
https://www.dodgeparts.com/part_number.html
Old Aug 29, 2007 | 09:56 PM
CaymanRam's Avatar
CaymanRam
Anyone know exactly know what it would be called to search for it. Is it a "trans controller"?
cost around $180.00?
or if anyone can find the part number let me know thx.
Old Aug 29, 2007 | 10:35 PM
master tech's Avatar
master tech
Site Moderator & Tech
The P0700 code is to let you know there are faults in the transsmission controller. The problem may not be with the controller , a problem with the trans. Maybe a sensor or an internal problem. You need to have a scanner hooked up to get the transmission codes out of the controller. If you are driving the truck and you have 1,2,3 gears and no 4,5 gears you may have a broken plate on the side of the valve body. But I amjust guesting.
Old Aug 30, 2007 | 12:56 AM
CaymanRam's Avatar
CaymanRam
a tech came from Miami and said it was a sensor, but the scanner wasnt pulling the exact one it was. i have all the gears in the truck...thought it was just a 4 speed auto though...no 5th. I am changing the one on the outside of the tranny first, and if that doesnt do it, then will do the one inside the tranny. I have the one outside already so i'm just goign to do that first. I can put the transmission in 2nd, and runs fine, just when its in "D" it shifts out at 3k rpm in 1st straight to 3rd.
