coolant flush ?
Old Aug 31, 2007 | 05:44 PM
287cc's Avatar
287cc
Default coolant flush ?
How are you guys busting the engine bolt (like stated in the haynes repair book)when you guys are flushing your coolant system?
Thanks
Old Aug 31, 2007 | 11:21 PM
ttuguy1983's Avatar
ttuguy1983
Default RE: coolant flush ?
walmart sells a nifty device that conects to a garden hose. it interlines with a radiator hose, and you can flush it very efficiently with pressure that way. i used one on my last vehicle and it worked pretty good. after i removed all of the coolant i opened the outlet on the radiator and let it flush for several minutes. then i ran prestone radiator flush and flushed again with the hose for several minutes. water came out very clear after the whole process. i think prestone makes the flush kit im refering to.
Old Sep 1, 2007 | 12:09 AM
287cc's Avatar
287cc
thanks for the response. So is it safe not to take the bolts out of the block? Those seem like a real b***h to take off.
Old Sep 1, 2007 | 12:16 AM
DeWalt378G's Avatar
DeWalt378G
yeah i wouldn't touch 'em. use the flush kit...so easy
Old Sep 1, 2007 | 12:52 AM
287cc's Avatar
287cc
Thanks! Picking up the kit tomorrow
Old Sep 4, 2007 | 08:32 PM
MikeHTally's Avatar
MikeHTally
Please be careful with the coolant you may spill on the ground! If you have animals, PLEASE don't let them drink it!!!!! I've used the coolant flush many times, but I'm hyper-super-mega careful to protect my furry friends.
Old Sep 4, 2007 | 09:12 PM
287cc's Avatar
287cc
First thing came to mind. Normally my pups are out with me in front yard but not the day I did the flush.
Old Sep 4, 2007 | 10:54 PM
HuntinHanson's Avatar
HuntinHanson
yeah the kit is soo simple to use. I did it the same time i put in my 180* thermostat...
Old Sep 4, 2007 | 11:28 PM
Hellbilly1's Avatar
Hellbilly1
unless you have cats to get rid of that ole antifreeze works wonders
Old Sep 5, 2007 | 12:07 AM
287cc's Avatar
287cc
Used the kit it works great.
