a few superchips questions
ORIGINAL: L and R Two
No the SC programmer won't tell you any of your times and gains. As far as warranties, you won't have any problems as long as you flash it back to stock before taking it in. Yes, the programmer can see if there was any mods prior to service but he has to dig deep into the program and most mfg's will not waste the time and just either flash your computer or do the repair and be done with it. I ahve had my truck in 2 x's. Once putting it back to stock and once not. Had no problems.
they say that one of these new updates for the SC will tell you these things....but i dunno, i cant update mine cause they dont have one that will work on Windows Vista [:@]
ORIGINAL: HansonHVAC
if you do get the flashpaq you can change the shift points on your own tho...
just wanted to mention that....
My bad........[:@]
i have a bully dog pogrammer and it gives none of the performance data either. however, i do have a g-tech pro that i got a steal on from ebay. if you want performance figures, then the g-tech pro is what you want.
ORIGINAL: ttuguy1983
The SuperChips Flashpaq does have a newer update that allows for tracking of run times, top speed over distance, and will monitor various sensors throughout your truck. These then can be downloaded onto your computer.
ORIGINAL: FFMedic1479
http://www.superchips.com/whats_new....new_item_key=9
just hop on ebay and order a performence meter from somewhere. the g-tech pro rr is a great one. you can get some others that just give you basic times like 0-60, 1/8th mile and 1/4 mile times for under 100 bucks.
