code meaning
Old Sep 7, 2007 | 02:34 PM
Spyder's Avatar
Spyder
Default code meaning
havent been here in a while but here goes...
my '02 ram 4.7L engine light came on and my code reader says its P0601. what does this mean, how much is it gonna cost me to fix and can i do it myself?
thanks
Old Sep 7, 2007 | 03:27 PM
kregier's Avatar
kregier
Default RE: code meaning
Not sure if it's the same, but for my '03 4.7 that code means 'Internal Control Module Memory Check Sum Error'. Try resetting your PCM?
Old Sep 7, 2007 | 04:19 PM
HAWKDRIVER's Avatar
HAWKDRIVER
Check the DIY section on 3rd Gen Ram. Someone posted a code library. Or go to autozone and borrow a scanner the call around to some shops.
Old Sep 7, 2007 | 04:39 PM
hemiyellow's Avatar
hemiyellow
DC Insider
it is:
Internal Memory Checksum Invalid
Old Sep 7, 2007 | 05:06 PM
Parts/Service's Avatar
Parts/Service
Is your truck running? Check with your dealer, This is usually covered under the 8 year/80,000 mile emissions warranty...
Symptom:
P0601-PCM INTERNAL CONTROLLER FAILURE
POSSIBLE CAUSES
POWERTRAIN CONTROL MODULE
TEST ACTION APPLICABILITY
NOTE: This DTC indicates an internal PCM problem.
If there are no possible causes remaining, view repair.
Repair
Replace and program the Powertrain Control Module in accordance
with the Service Information.
