Rear Axle Question?
Old Sep 9, 2007 | 05:04 AM
ozzy55's Avatar
ozzy55
Default Rear Axle Question?
Hey everyone, I Was reading my build sheetJust trying to learn more about my Truck, I understand the Anti-Spin Diff is the same as limited slip, but what is meant by Lock-Up Torque Converter? is this the same on all Rams or is it an added option?Thanks for anyinformation.
DHAP - Lock-Up Torque Converter
DMHP - 3.92 Axle Ratio
DRBS - Corporate 9.25 LD Rear Axle
DSAP - Anti-Spin Differential Rear Axle
Old Sep 9, 2007 | 07:53 AM
OldMoparMan's Avatar
OldMoparMan
Default RE: Rear Axle Question?
A lock-up torque converter does exactly that, "Locks up" into gear to provide overdrive. It can be mechanically or electronically activated. Most are electrical anymore.
Old Sep 9, 2007 | 11:06 AM
HuntinHanson's Avatar
HuntinHanson
Yep, without that, your not going to go anywhere...
Old Sep 9, 2007 | 11:38 AM
Hemiriden's Avatar
Hemiriden
the lockup torque converter is good... the lock-up is not required for a torque converter.... Read this "How Stuff Works" and you will know how it works.... the "Lock-Up" is a special added feature... after reading the information you will understand that Essentially the engine is COMPLETELY disconnected from the tranny.... it uses fluid coupling to spin the tranny. So the engine is usualy spinning FASTER then the tranny most the time... read below:
At higher speeds, the transmission catches up to the engine, eventually moving at almost the same speed. Ideally, though, the transmission would move at exactly the same speed as the engine, because this difference in speed wastes power. This is part of the reason why cars with automatic transmissions get worse gas mileagethan cars with manual transmissions.
To counter this effect, some cars have a torque converter with a lockup clutch. When the two halves of the torque converter get up to speed, this clutch locks them together, eliminating the slippage and improving efficiency.
In answer to yoru question.... It is standard on 3rd gen5 Speed and Multi-Speed Overdrive Automatic Transmissions. Other trannies do not have the lockup for example... The ramV6 has a 4 speed tranny and NO lock-up feature.
-R
Old Sep 10, 2007 | 03:12 AM
ozzy55's Avatar
ozzy55
Thanks , I am learning a lot here on the Forum
Old Sep 10, 2007 | 07:20 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
I love the how stuff works site. They have a ton of good info there.
