lil help with the warning.
Old Sep 16, 2007 | 08:02 PM
manogmin's Avatar
manogmin
Default lil help with the warning.
when i honk the horn, or use the fob to lock the door, the horn recently started not working properly. it honks but sounds kinda like they are plugged up with something, i think i need to replace them, but any other less labor intensive ideas? could it be a fuse even though it still sounds, but not normally? fyi - i havent looked at the fuses yet, didnt have time before it got dark, and was feeling kind of lazy. thx for all the help.
Old Sep 16, 2007 | 08:09 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: lil help with the warning.
Not the fuse is you are getting any sound at all. The horn could be bad, it is not a common thing but it happens. Horns are small and easy to replace. You can get a replacement horn from you local shop for around $10.00. Hell you could upgrade to a funky horn for around $30.00 or you could do what I did and go with airhorns (but they are a little more expensive and if you don't know what you are doing, they are kinda hard to install).
Old Sep 17, 2007 | 03:57 PM
#Red's Avatar
#Red
You may have a bee's nest in your horn. Locate it and check it out. Red
Old Sep 18, 2007 | 09:16 AM
Duso02's Avatar
Duso02
Loose ground.
Old Sep 19, 2007 | 06:50 PM
manogmin's Avatar
manogmin
i found the problem ... there was mud in the horns. i guess i went a lil too dep. didnt get stuck though.
