Lift Questions
Old Sep 16, 2007 | 09:50 PM
SWOS Chief's Avatar
SWOS Chief
Default Lift Questions
Ok, so I have a few questions for you all, if you have a few minutes. Feel free to post here or email me at minarya002@yahoo.com. Thanks ahead of time.
1. What is the difference between a leveling kit and a leveling lift kit?
2. Fabtech has two 6" lifts available, the only difference I see is one has coil over springs and costs twice as much, why?
3. Will places like Top Gun Customz let me switch the Fabtech shocks for Bilstein? (figuring I can email them to ask but would ask here first)
4. Fabtech or Pro Comp?
5. Do some kits come for the front only to give the "Baja" look? I don't want this look so I want to make sure.
6. I am a shade tree mechanic but am in the Navy with many, next to, professional mechanis around me and access to autobody shop with all the tools I would ever need and a lift on base. Is it possible for me to do this myself or look to have it installed?
7. I know the law about aftermarket stuff not voiding a warranty, but, if something goes wrong and it can be shown that the installed lift caused it, is my warranty nill and void?
8. What is backspacing and how does it tie into this?
9. Last but not least, is there a reason the University of Nebraska renewed Bill Callahans contract prior to one of biggest games in Nebraska history only to see him fall on his face?
Old Sep 16, 2007 | 11:21 PM
marv02's Avatar
marv02
Default RE: Lift Questions
Fabtech or CTS lift
Old Sep 17, 2007 | 12:08 AM
prerunner's Avatar
prerunner
Nothing....there both the same
The coilover system is much more expensive. It replaces the front shock and spring!!!
The cheaper version just comes with a 6" drop spacer to move the stock shock/spring.
Probably not, unless u want to pay the extra cash for the bilsteins!!!
Just had the Pro Comp installed in mine. So far i liky
I'm sure someone will make one like that, but the fabtech and pro comp are not.
I had mine installed, simply because i want someone else to blame if something goes wrong!!!! I believe there are only two cuts for either system. THe rest is direct bolt on!
If u lift.....forget about tranny/driveline/diff/suspension warrantys!!!
Backspacing is for the rims. Tells you how far the rim sticks out.
Go Huskys....i have nothing more to say
