sound from front suspension
Old Sep 18, 2007 | 09:06 PM
BOES383's Avatar
BOES383
Default RE: sound from front suspension
I've been fighting a similar issue for quite awhile.
I've had it to my purchasing dealer, and more than one tire/suspension shop. No luck.
I ended up finding the problem during an oil change... was underneath the truck pounding (with the palm of my hand) alot of the suspension pieces trying to duplicate the sound. Found it.
At some point the front, passenger side sway bar link had failed. It APPEARED to be comlpete, but was in two piecesandmaking a helluva lotta noise!
Cost me roughly $36.00 to replace link and bushings.
Problem cured.
Might want to check this area. Just a thought.
Old Sep 19, 2007 | 06:52 PM
masonman85's Avatar
masonman85
dang i thought for sure it could have been the sway bar but i couldn't get it to make ne sound and it was on there pretty firm. thanks for all the tips guys i guess i'll have to wait for something to fail seriously bad before i figure out where this sound is coming from...despite taking it to my dealer i dont think they are the greatest...the failed to properly install my front passenger driveshaft and when i told them it was wrong they told me it was on there good....chief mechanic finally got involved and fixed the problem...i could pull the damn thing almost all the way off the splines and they told me it was fine lol...anyways thanks again...hopefully i'll find it before the serious failure lol
Old Sep 19, 2007 | 08:26 PM
OldMoparMan's Avatar
OldMoparMan
DC is notorious for bad sway bar bushings. Spraying them will do nothing. You need to drop the "U" straps, remove the rubber bushings and lube INSIDE where the rubber wraps around the swaybar. Check there first.....
Old Sep 19, 2007 | 08:33 PM
brianas's Avatar
brianas
my 06 ram, makes this knocking sound from the front end when going over bumps,
steering wheel shakes a little also, im not sure what it is , but when i hit a bump at speed on the
highway and it does it -truck loses control for a sec.
i kinda suspect those soft control arm bushings
Old Sep 19, 2007 | 09:16 PM
masonman85's Avatar
masonman85
old mopar man i think u've got it...only problem is that i dont have the time nor the skill to do that lol....i work construction and its very very dusty conditions...i wouldn't be surprised if those bushings are dry as a bone inside and to be honest its sounds like it would be that as well....maybe i should take it in and make them replace my soft bushing with the hard ones does neone have that referance number? and do i still have to pay for them to do that i remeber several discussions on front end vibrations because of soft bushings
Old Sep 19, 2007 | 10:46 PM
cableguy1224's Avatar
cableguy1224
My 05 with 13,000 milesdoes the same thing, I have been beating my headover this issue for a while now, The dealer said the only thing it might be is the little bit of play I'm hearing in the steering column. I dont believe that for a second though
Theycannot find or fix this issue and it is killing me!!!.
ALso I know its not a shock issue because I replaced all 4
Old Sep 19, 2007 | 11:34 PM
masonman85's Avatar
masonman85
glad i'm not the only one
Old Sep 20, 2007 | 12:24 AM
chefred112's Avatar
chefred112
....does it sound like 2 squirrels humping...a squeak, squeak?... I had a similar noise on my 05 which i could swear was suspension bushings or something...but it turned out to be my hood bumpstops... I turned them up to the point that i had to almost slam my hood to close...that was it..
[IMG]local://upfiles/13436/AE073310B361427E9EDDC003EF337E68.jpg[/IMG]
Old Sep 20, 2007 | 12:27 AM
chefred112's Avatar
chefred112
...it's a cheap no cost fix..if it works...hehe... it doesn't hurt to try...
Old Sep 20, 2007 | 07:29 AM
masonman85's Avatar
masonman85
thanks for the tip i'll take a look its worth a shot
