check engine light (AGAIN)
Old Sep 19, 2007 | 12:05 PM
TRUDAROOF's Avatar
TRUDAROOF
Default check engine light (AGAIN)
I just had both Heads replaced less then a week ago & now my check engine light is on again..... now it's P0455 (M)Evap Leak Monitor Large Leak Detected A Large Leak has been detected in the evaporative system. Does anybody know what that means and is it something that could'vehappened while they were installing the Heads.
Old Sep 19, 2007 | 02:24 PM
tdmopar59's Avatar
tdmopar59
Default RE: check engine light (AGAIN)
possibly i would try calling whoever installed your heads because there is a good chance they might have had something to do with it. this link might be helpful for you as well
http://autorepair.about.com/library/a/1h/bl010h.htm
Old Sep 19, 2007 | 04:25 PM
Duso02's Avatar
Duso02
The large EVAP leak has to do with a vacuum leak in your EVAP system. 9 out of 10, it's a bad gas cap or the truck was started with the gas cap off.
