Clearing computer?
Old Sep 21, 2007 | 05:53 PM
HAWKDRIVER's Avatar
HAWKDRIVER
Default RE: Clearing computer?
Never even thought of that. I've owned my truck since new but sometimes I take it real easy to save on fuel. I'm gonna try the reset.
Old Sep 21, 2007 | 06:06 PM
OldMoparMan's Avatar
OldMoparMan
I"m not going to pretend to know EXACTLY how it works, but I believe that the computer has parameters to learn different types of driving habits, based on TPS readins, Detent readings and Speed sensor readings. It probably takes an average of these, and adjusts the ECM accordingly.
With that being said, if you've owned your truck since new, I don't really see a reason to reset anything. How you drive, on an average, is how the truck will set itself.
My Silverado took almost 400 miles before the trans shifted consistently (although not a DC product) where it didn't vary any more.
My 2005 Grand Caravan took a few hundred miles as well.
The Ram took about 50-60 until decent shifting was noted, (less SuperChips) and about 200 miles till it was consistant.
Once I applied the SuperChips program (91 octane) it was within less then 20 miles till a difference was felt, on a regular, consistent basis.
Old Sep 21, 2007 | 06:17 PM
nastyram's Avatar
nastyram
the only thing i'm scared of is i think i got a flutek,i mean ever since i got the truck(bone stock)it run alot better than other 4.7s,my boss had the samething an mine would smoke his by like two truck lengths,raced a few others an the same thing,well i guess it dosn't hurt to try
Old Sep 21, 2007 | 06:26 PM
kenihemi's Avatar
kenihemi
Our pcm's learn as you drive, make no mistake about it.
The numbers are called adaptives. The adaptives that effect mpg are long term and short term fuel trims.
You need a scanner to read them.
The turbo and sc guys know more about that then they ever wanted too.
If you reset the pcm properly, you set the adaptives back to zero. Now the pcm learns all over again and makes adjustments as needed.
Our trucks run pretty much stoich (14.7 A/F) at idle and mid throttle, then richen it up for WOT. The adaptives that the pcm sets are what make that happen.
Old Sep 21, 2007 | 07:53 PM
nastyram's Avatar
nastyram
well i did it runs the same but just whent up the road so miles will tell,did notice with out superchips would not spin tire,inshalled it up in smoke they whent
Old Sep 22, 2007 | 12:22 AM
chefred112's Avatar
chefred112
on 04's an 05's, fuse 23 is the pcm, pull it out, then do the start thing as mentioned above...and NO, on 04's an 05's (i know these, not sure on others)..the truck will not start or turn on..just ding...I do this every once in awhile so that the pcm relearns...
Old Sep 22, 2007 | 12:28 AM
chefred112's Avatar
chefred112
try this trick, i do this when I go to the track...turn the key to the on position (dings, an dash light etc)...slowly depress the pedal all the way to the floor, hold for 10-15 secs, then slowly let off the pedal, turn key off..... this resets our fly-by-wire throttle. you instantly feel it respond quicker wen you push the gas...
Old Sep 22, 2007 | 07:24 AM
HankL's Avatar
HankL
It is my understanding that on 3rd Gen Ram engines
the two things that 'learn' are the short term and long term fuel trim memory registers,
and these work only during part throttle driving
as a 'speed up' to allow the oxygen sensor
get the air/fuel ratio into the 14.7 'window' faster.
Once you go above 80% throttle to wide open throttle
the PCM computer uses fixed tables to inject fuel and set ignition timing.
The above 80% throttle engine also stops being low pollution and can emit anything but black smoke....this "safety passing power" loophole in the Clean Air Act that has been defended from change by high senority Michigan Representive John Dingel from changes in the law is not well known by vehicle owners.
Bottom line: resetting your PCM computer will not improve your full throttle engine performance.
Resetting will make the air to fuel richer at part throttle and make the enigne seem 'smoother' for a short period until the PCM fuel trims 'learn' the correct values again...which they usually do within 20 minutes.
Old Sep 22, 2007 | 12:30 PM
kenihemi's Avatar
kenihemi
QUOTE!
"It is my understanding that on 3rd Gen Ram engines
Resetting will make the air to fuel richer at part throttle and make the enigne seem 'smoother' for a short period until the PCM fuel trims 'learn' the correct values again...which they usually do within 20 minutes."
Hank,
That is a good write up. The WOT fixed numbers are preset in the pcm while its in 'open-loop'. It goes into open-loop somewhere in the 80 percentile throttle position area. In open loop, the pcm isn't even reading the o2 sensors or knock sensors.
Old May 25, 2013 | 09:17 PM
pieceworker's Avatar
pieceworker
Wont turn over.Ecm/skim fuse n o2 senso
r does not work.i mean i used a light up wire checker.every other fuse slot lit up exept those two..help please.
