Climbing hills?
Old Sep 25, 2007 | 07:06 PM
Colin467's Avatar
Colin467
Default Climbing hills?
hi i have a 4.7 4x4 with 3.55 gears and when ever i go up hill it goes from about 1500 rpm to 3400 rpm to climb the damn thing. is there any thing i can do to fix this should i get a gear swap to 4.56 and if so do you know how much that would cost or is it just normal for it to down shift gears like that ?
Old Sep 25, 2007 | 08:01 PM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: Climbing hills?
4.56 would be pretty drastic
Old Sep 25, 2007 | 08:17 PM
nastyram's Avatar
nastyram
its going to cost a good penny,(don't forget you haft to do the front to),had the same problem,the headers and tb made a nice differeance but thats not cheap neither
Old Sep 25, 2007 | 08:29 PM
DeWalt378G's Avatar
DeWalt378G
i had the 3.55's too andjust went to 410 and it seems real good. 410 is a pretty good all around gear. it will be expensive though.
Old Sep 25, 2007 | 10:31 PM
steve05ram360's Avatar
steve05ram360
you could back off the throttle and then it wont go to 3400 rpms... let the torque push you over the hill
Old Sep 25, 2007 | 11:48 PM
kx250frider617's Avatar
kx250frider617
well in my truck when towing up a hill, it will hit that 3000 rpm's then it just won't slow down, it just keeps speeding.
Old Sep 26, 2007 | 02:17 PM
Colin467's Avatar
Colin467
ORIGINAL: steve05ram360
If i dont hold the throttle it slows down to around 45mph from 60mph
Old Sep 26, 2007 | 02:31 PM
steve05ram360
one option is to wrap your fuel rails to keep the heat soak off them... it will help with the low/mid range power. If motivated.. you can take it a step further and go with a fuel cooler. I did this on my 2000 and it gave me 6% better mileage on the hiway. when I sold the truck I took off all the mods and sold the cooler to a 2nd gen owner who put it on in front of his e-fans... his response was very enthusiastic... he mentioned a good low/mid range bump in power.
Old Sep 26, 2007 | 02:32 PM
motorhead426's Avatar
motorhead426
I went from 3.55's to 4.56' and drove from Michigan to Georgia over Easter this past April. Driving through the mountains with the new gears and larger MT's made a huge difference. I can probably count on one hand how many times the truck downshifted on grades.Unless it was really steep.
Old Sep 26, 2007 | 02:35 PM
Colin467's Avatar
Colin467
ok where would i get a cooler for it?
