Iridium spark plugs.
ORIGINAL: HankL
Sparkplug designs with tiny & sharp center electrodes seem to be the trend of the future.
To keep the tiny electrode from melting they add the rare earth metal irridium to the alloy used. It is not pure irridium, and has platinum and other metals.
People who work in Chrysler's Dyno test room have reported that the 5.7 is within 5 degrees of 'best torque' ignition timing on 89 octane gasoline.
Using an irridium tipped sparkplug set at a wide 0.060 gap with both sparkplugs indexed so that the open gap is in the direction of the center of the cylinder and the ground post is over toward the cylinder wall is a mod worth investigating, along with a change to 93 octane gasoline for a margin of safety against detonation.
The sharp center tip, big gap and indexing
would probably increase
'fast burn'
enough to advance the 'real world' burn timing
from the factory 5 degrees past top dead center
to close to the 10-12 degrees past top dead center
where maximum torque is made
when cylinder pressure peaks at this position instead of sooner.
Want more info on 'real world' ignition timing?
This article from Australia is good:
https://dodgeforum.com/m_982171/tm.htm
'fast burn'
Are they worth getting for the extra Money or Not.
You know -- HankL always has an awesome array of facts and information, which I appreciate a great deal. But I gotta ask ya Hank, why do you speak as if you are a robot, training other little robots on the planet OObu?
Whether the cost is worth it is up to you
although the irridium plugs seem to never wear out.
Mopar Muscle on 5.7 Hemi indexing potential:
http://www.moparmusclemagazine.com/t.../photo_03.html
Let's see now....
you want accurate facts from a sworn to be truthful registered professional engineer,
you want writing as funny and enjoyable as Mark Twain, Dave Barry, or Mike Myers
and you want it to be.....totally free
I went in to town today with the wife and I pick up a set of plugs I was getting NGK Coppers at Kragens Auto but as my luck they did not have a set so I ended up getting NGK Iridium plugs Stuck them in when I got home so far the truck runs Good.
Oh yea the 06 3.7 comes with NGK Coppers Stock.
