help reseting pcm need fuse #
Old Oct 1, 2007 | 07:09 PM
clubin11's Avatar
clubin11
Default help reseting pcm need fuse #
im going to reset my pcm but i can find which fuse to pull can anyone help me in which one to pull then i know the procedure. the fuse top didnt say which fuse was for pcm so i herd it was fuse 11 is this true or is there others or more any help will be greatly appreciated
Old Oct 1, 2007 | 08:57 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: help reseting pcm need fuse #
<rubbing my magic ball>.... I can see your truck.... it's not running as wanted....I am seeing a blank spot in your expression.... curiosity is striking deep within mind... and everyone else around here knows what truck you have... and no one can help..... Well... wait....I was wrong.. no one knows what you have.... Bummer....[sm=huh.gif]
Old Oct 1, 2007 | 09:35 PM
HammerZ71's Avatar
HammerZ71
I have no idea what fuse it is in your '02 5.9. You may have to go to the manual, I'm surprised it's not on the fuse box cover, my cover labels every one. I'd hold off on the reset though, if you are getting the headers for sure, reset right after the headers are on.
Old Oct 1, 2007 | 10:34 PM
clubin11's Avatar
clubin11
yea im think im going to wait but i looked on the cap it labels them all but none of them say pcm so idk what to do
Old Oct 1, 2007 | 10:42 PM
Max Power's Avatar
Max Power
ORIGINAL: 07 Ram TRX4
LOL!!!
Old Oct 2, 2007 | 12:17 AM
gchildre's Avatar
gchildre
ALLDATA doesn't list a fuse for the PCM, they elude to a ground switch from arelay. I guess you'll have to just disconnect the battery to reset it.
Old Oct 2, 2007 | 08:01 AM
tdmopar59's Avatar
tdmopar59
you could even check online for a manual online... that will prolly give you some info
