anyone plow?
Old Oct 4, 2007 | 07:17 PM
wraith05ram's Avatar
wraith05ram
Default anyone plow?
Does anyone plow with a 3rd gen Ram 1500? I'm thinkin of getting one for this winter and I'm looking for any recommendations or preferences.
thanks
Old Oct 4, 2007 | 10:50 PM
tdmopar59's Avatar
tdmopar59
Default RE: anyone plow?
i wouldnt plow too much with a 1500... thats more of an hd thing or an ol beater truck...
Old Oct 5, 2007 | 12:03 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I believe the manual says NOT to plow with the 1500. Something about the airbag sensors or something like that, I think. I believe it can void your warranty if it's damaged due to using a plow.
Old Oct 5, 2007 | 08:08 AM
#Red's Avatar
#Red
Your truck will do it with no problem. Here is another active link about the same issue; https://dodgeforum.com/m_991339/tm.htm. I would just put the plow on when you are going to use it, don't leave it on for the next storm two weeks from now. Red
Old Oct 5, 2007 | 09:07 AM
cpukramer's Avatar
cpukramer
You CAN plow with the 1500 but if you can afford it I really reccomend going with a solid front axle 2500 or get an older beater where you don't care if you screw it up too much. Also a lot of the older truck (I believe all of the 2nd gen Rams, but I could be wrong) have solid front axles. If you decide to do it anyways, stick with a lighter duty residential plow. I plowed for a while with a 1500 Chevy beater truck. Worked OK but when I went to a bigger industrial size plow I had to but bigger coil springs in the front to keep it from sagging. I used all Western plows, I had the UniMount for awhile and now I have the UltraMount ProPlow with side wings. Also definitly go with a 1000CCA battery or you will be replacing your battery all the time.
oh ya and you will probably void your warranty if you bring it to the dealer with the plow frame attached, so keep that in mind. You will have to take the plow mount off before taking it in for service, and even then you are rolling the dice [&:]
Old Oct 5, 2007 | 11:17 AM
Joel_MD's Avatar
Joel_MD
I did a lot of snow plowing when I lived in MN in the '80s and '90s. Plowing tends to wear everything out on your truck. I strongly suggest you not mount a snowplow to a half ton truck, especially a nice one like yours. The weight of a snowplow is centeredseveral feet in front of the front axle, which compresses the front springs and unloads the rear springs.
Whatever truck you use, Isuggest a high quality plow like a Western. I haven't looked at new snowplows for years, but the good ones had manual hydraulic valves actuated by cables instead ofsolonoids. The manual valveswill last forever,and the solonoids tend to wear out. Also, a dual battery setup with a big alternator (or even two small alternators) is a big plus. The motor that drives the hydraulic pump is basically like a starter motor, and has a huge amp draw when you raise the blade or angle it.
Old Oct 16, 2007 | 11:57 PM
wraith05ram
well thanks for the input but my main question was regarding whatbrand plow would be best. i really dont doubt i'll have any trouble doing it with my truck considering my cousin had a 2500 hd chevy with a plow and said that his best plow truck was his 01 dakota v6 with a 7 ft plow
