Towing Specs-help
Old Oct 6, 2007 | 09:35 AM
waltmoe's Avatar
waltmoe
Default Towing Specs-help
I am going to purchase a 5th wheel to haul behind my 07 RAM 3500 Quad cab, 4X4, 5.9 automatic, 3.73 rear end gearing, NON dual wheels. I am beatingmy head against the wall attempting to find any data on the tow capacity of my truck. I'm a little confused that Dodge does nothave any stickers on the door post indicating max tow data.
Does anyone know of any resources where I can get accurate tow capacity data for my truck? I checked the Dodge web site and they show the 2007 6.7 but no 5.9 data.
Old Oct 6, 2007 | 09:39 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Towing Specs-help
Dodge use to have a spot where you put in your info and it showed you, but I can not find it. So try this site.
http://trailmanor.com/WebDocs/Campin...icleSearch.php
http://trailmanor.com/WebDocs/Campin...hModels=Go+%3E
Old Oct 6, 2007 | 09:48 AM
Kev_n_AZ's Avatar
Kev_n_AZ
waltmoe
are you refering to a 5.9 cummins??? then step inot the cummins diesel section me friend... https://dodgeforum.com/forumid_143/tt.htm
anyway, if ya call the dealer, they should be able to tell ya.
Old Oct 6, 2007 | 11:52 AM
hemiyellow's Avatar
hemiyellow
DC Insider
has to be refering to the 5.9 CTD cause the 360 was discontinued back after 2002 for the 2500/3500
Old Oct 6, 2007 | 01:19 PM
kx250frider617's Avatar
kx250frider617
what size 5th wheel? I think once you get into the 40footers it would be better to have a dually.
Old Oct 6, 2007 | 03:53 PM
helopilot's Avatar
helopilot
Dodge towing specs
http://www-5.dodge.com/vehsuite/TowingGuide.jsp
