tmr mod question
Was just getting ready to ask that, saw the thread yesterday and thought someone else might answer and I wouldn't have to. Don't feel alone brother, I have no idea either.
its a mod that you pull a wire from the pcm and it takesaway the torque managment system from your trans so that you have firm shifts instead of buying a shif kit i would rather do this but nobody will help me lol but i think they would help me if they coudl
If you go over to the Dodge talk.com and search the same thing, you'll see it discussed. The link I posted won't open for some reason, so I deleted it. My bad..........
Now.....applying power to the purple wire may or may not do the same thing, taking into consideration that the Dodge Ram's trans has had issues in the past, is shifting it under full power something you want to do, on a regular basis?
I was advised once that the reason Superchips doesn't program the trans to shift harder then it does, is due to possible damage. In comparison to some Chevrolets I've owned, the Dodge trans shifts much softer, even after reprogramming.
Take it for what it's worth.... Just throwing that out there.
Trending Topics
can anyone help me with the tmr mod i want it but cant seem to find out how to do it on the pcm there are 2 black connectors and one white in the middle and i cant find the wire so is i dont have it or im blind someone help me out ican get pics if wanted
