Wierd Problem
Old Oct 10, 2007 | 05:31 AM
trapp40's Avatar
trapp40
Default Wierd Problem
I have a 03 Ram with 185,000 miles and my problem started a few months ago. When running the AC, the air on the drivers side ventsis cold and the air on the passanger side was just cool.I decided to try the heat and see if it did the same thing and it is opposite. The drivers sides vents blow cool air and the passanger side blows warm air.Any ideas what the problem is?
Thanks in advance
Old Oct 10, 2007 | 05:54 AM
Beezz27's Avatar
Beezz27
Default RE: Wierd Problem
Does it have dual zone climate control? If so it sounds like you have an air temp blend door problem.
Old Oct 10, 2007 | 08:38 AM
Max00racer's Avatar
Max00racer
ORIGINAL: Beezz27
"it sounds like you have an air temp blend door problem."
thats a mouthful haha
Old Oct 11, 2007 | 09:33 AM
trapp40's Avatar
trapp40
No, I do not have dual zone. I can't figure out what the problem could be
Old Oct 11, 2007 | 10:02 AM
OldMoparMan's Avatar
OldMoparMan
ORIGINAL: trapp40
I have a 03 Ram with 185,000 miles .....
I'm just pleased as pie to read the first line...................
Your temp doors are controled by vacuum. Sounds as if there's a line disconnected or broken, or a vacuum control podwent bad. (or stuck door)
You'll have to lay on the floor and check under the dash to make sure things are hooked up. Not sure if there's a junction off the back of the control unit or not, but that's suspect as well, if there is.
Suspect the passenger side, as it blows hot air, with A/C on. Sounds like the temp door is failing to close, allowing only cold, A/C air to flow through.
Old Oct 11, 2007 | 10:07 AM
tdmopar59's Avatar
tdmopar59
ORIGINAL: OldMoparMan
ORIGINAL: trapp40
+1 i think its just some kind of small leak..
Old Oct 11, 2007 | 10:56 AM
Duso02's Avatar
Duso02
Somebody on here had this, I think it was a mixing door stuck. Turned out to be quite common.
Old Oct 12, 2007 | 06:24 AM
trapp40's Avatar
trapp40
[quote]ORIGINAL: OldMoparMan
I have been pleased too.I bought the truck new and all I have had to do to the truckis change the TPS. Believe it or not, I put the first replacement spark plugs in it at 175k and it was running fine then.
Thanks for the help!
