Towing: Is my 1500 gonna handle it?
Old Oct 11, 2007 | 10:41 PM
  #21
NYPANAMA42's Avatar
NYPANAMA42
Default RE: Towing: Is my 1500 gonna handle it?
ORIGINAL: HammerZ71
Not on an everyday basis, but occasionally you should have no problems. It would not be a bad idea to have a tranny temp gauge installed, you can get a really cool setup that replaces your driver side pillar. Fairly cheap, I'm thinking maybe $200 for pillar & gauge.
The tranny is the one component more likely to fail during towing so monitoring the temp. would be a good safeguard. Also, servicing the rear differential and tranny fluids about twice as often as the manual calls for is another pretty good safeguard. With a lot of towing, you should also think about changing engine oil & possibly radiator fluids more often than when you didn't tow. Of course, brakes will wear out faster stopping a heavy load so just keep an eye out there too.
That should really about do it. I'll try to find a pic of that replacement pillar & gauge and possibly a link to purchase it.
Here is one for about $50.00, the actual temp gauge is probably about that much and to have someone run the wire might cost you $100 tops as it's only about a half hour job.
Nice setup..Did you do the install yourself? Or did a shop do it for you....How much did it cost to install?
Old Oct 11, 2007 | 10:49 PM
  #22
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: husley
We have a 02' 1500 Quad Cab Long Bed with the 5.9L V8.
The manual states that 8000lbs is the max towing.
We are getting a trailer that is 5000lbs and will probably be around 6000lbs when it is loaded.
We will be towing it at the most two times a month (travel trailer)
Are we going to destroy our Truck towing this Trailer?
All input is appreciated!
Thanks
Karna and Justin
Absolutely will destroy it. the 1/2 tons have a lower tow capacity then a toyota Yaris.
Seriously you should be alright. jsut keep your truck from shifting too much by either using tow haul mode or by kicking off the over drive.
Old Oct 12, 2007 | 12:10 AM
  #23
JD1500's Avatar
JD1500
Oh yes, i forgot about that. all the mechanics have told me the weight is not a problem. but to BE SURE you have it in tow haul mode when doing moderate to heavy pulls. Prime gears are teh weak ones
Old Oct 12, 2007 | 11:50 AM
  #24
NYPANAMA42's Avatar
NYPANAMA42
ORIGINAL: JD1500
Question: Aside from the engine, of course. Are the Hemi's tranny designed differently from the regular 4.7 LTR V-8's?
I ask because i don't think i have this "Tow Haul Mode" with my truck. Although i do have a O/D swich.
Old Oct 12, 2007 | 02:04 PM
  #25
JBoze's Avatar
JBoze
The question isn't if the truck can tow 8,000 lbs, it's can it STOP it!? Your truck will yank a lot more than 8,000lbs, but stopping it is going to be a problem!
Old Oct 12, 2007 | 02:11 PM
  #26
tnt1036's Avatar
tnt1036
Question on the tow haul mode. When I get it up to speed on the flat highway at 65mph can I turn it off?
Old Oct 12, 2007 | 02:27 PM
  #27
JayH2112's Avatar
JayH2112
In response to tnt1036, I would say yes to that as long as you aren't lugging it or getting alot of downshifting.
Old Oct 12, 2007 | 03:12 PM
  #28
topcop38's Avatar
topcop38
i just towed my trailer 800 miles round trip all highway with tow/haul enabled and got 9 mpg. i didn'ttry it with tow/haul off. i wascruising at 2700 rpm.
Old Oct 12, 2007 | 09:29 PM
  #29
HammerZ71's Avatar
HammerZ71
ORIGINAL: NYPANAMA42
I don't have one, it's the picture off the website of one of the places that sells it. I was just saying it would be a very good, inexpensive investment for someone who tows heavy weight to be able to monitor the tranny temp. as this is the one place that NEEDS monitoring during heavy towing.
I don't tow, sold my 20' bass boat after both my parents fell ill. I have little time for much, and actually was in it twice in the past year and a half so I sold it. Heaviest thing I move now is my 650# ATV and I carry that in the bed.
I was actually thinking of getting it, and one of those rear diff. covers with the bung for temp probe in it (like the MagHytec) and monitoring rear diff fluid temp as I have aftermarket 4.56 gears. Marty at KRC Performance sells the replacement pillar for $60 and the gauge for $35 and would run the probe to either place for an hour labor or $70.
They also make the pillar with 2 guage openings, so you could do both, but you give up the handle, and my truck is lifted to high, I use the handle every time I get in, so that's out.
Old Oct 12, 2007 | 10:24 PM
  #30
Silver Eagle's Avatar
Silver Eagle
What ever you do ,don't use the cheap rubber hoses that come with the cooler's.Get the braded high pressure one's they wont come apart on the inside and clog your transmission filter .I voice of experiance.
[/align]
