Program Keyless entry?
Old Oct 13, 2007 | 08:00 PM
chopperzen's Avatar
chopperzen
Default Program Keyless entry?
I found a remote for keyless entry, but don't know how to program it. Anyone know how to do this without going to a dealer? It's a 2003 quadcab.
Old Oct 13, 2007 | 09:39 PM
Parts/Service's Avatar
Parts/Service
Default RE: Program Keyless entry?
If you already have a fob that is programmed to your truck then this should work......If you don't have 1 already, you are dealer bound....
The following procedure can be used as long as one programmed transmitter is available:
NOTE: When entering program mode using that programmed fob, ALL currently programmed fobs will be erased and they will have to be reprogrammed for the vehicle. If program mode is entered and no action is performed, the previously programmed fobs will continue to function.
[ol][*]Enter the vehicle and close all doors.[*]Fasten the seat belt (this will cancel the seat belt chime). Turn the ignition to the RUN position.[*]Press and hold the UNLOCK button on a programmed transmitter for 4 to 10 seconds. Within the 4 to 10 seconds with the UNLOCK button still depressed, press the PANIC button for one second. When a single chime is heard, release both buttons.The chime indicates the system is in program mode.[*]Press and release both the LOCK and UNLOCK buttons simultaneously on a fob to be programmed. A single chime will be heard, this indicates the fob has been recognized.[*]Press and release any button on the same fob. A single chime will be heard, this indicates the fob has been programmed.[*]Repeat steps 4 and 5 for up to a total of 4 fobs.[*]Turn the ignition OFF.[*]Turn the ignition ON or wait 60 seconds.
The vehicle will remain in program mode for up to 60 seconds from when the original chime (step 3) was heard. After 60 seconds, all programmed transmitters will function normally.[/ol]
Old Oct 16, 2007 | 08:44 AM
chopperzen's Avatar
chopperzen
I don't have a remote. There is no way I canprogram it without going to a dealer?
Old Oct 16, 2007 | 01:29 PM
Parts/Service
No way without at least 1 original fob, sorry
