OVERHEAD CONSOLE - REMOVAL
Old Oct 15, 2007 | 12:09 AM
pcfred's Avatar
pcfred
Default OVERHEAD CONSOLE - REMOVAL
How do I remove the cover of the overhead console? I have the short console without the eyeglass holder.
I want to tap into the power to supply my rearview camera screen.
Old Oct 15, 2007 | 10:00 AM
tdmopar59's Avatar
tdmopar59
Default RE: OVERHEAD CONSOLE - REMOVAL
you pop off the two light covers with a regular screw driver than look for the torx head screws... take them out and wala
Old Oct 15, 2007 | 07:18 PM
MikeHTally's Avatar
MikeHTally
Yep, I've taken mine down several times. Be careful to pop the outer hinge pins first. I had problems finding a power source there, though. Wound up having to run down the A-pillar. There's a very convenient power source that's only on with the motor running.It's behind the bolster panel under the steering wheel.
Old Oct 16, 2007 | 02:34 PM
Foiled's Avatar
Foiled
ORIGINAL: MikeHTally
Can you give a little more info on this? I would like to tap into that hot if it is only on while the engine is running.
Old Oct 20, 2007 | 01:27 AM
pcfred's Avatar
pcfred
Got the console off and tapped into the display power for my backup camera screen, works good. Good info about the power source behind the bolster, thanks.
Old Oct 20, 2007 | 08:58 AM
MikeHTally's Avatar
MikeHTally
Took these pics this morning. The lit grn wire with a black stripe is hot only when the ignition switch is on "run". It is not hot when switched to "acc".
