lift need help
Old Oct 16, 2007 | 10:35 PM
minyo16's Avatar
minyo16
Default lift need help
i have a 6" lift and i am putting 35s on it. does anyone know how high it will sit from stock and the gas mileg. and what are good tires to get. also what can i do to save gas with them like powerchips? and also the same ? if i got 37s that and email me at minyo16@hotmail.com.
thanks
Old Oct 16, 2007 | 11:28 PM
HammerZ71's Avatar
HammerZ71
Default RE: lift need help
Needs specs on your truck first. Year, model, engine, etc.
Old Oct 16, 2007 | 11:33 PM
tdmopar59's Avatar
tdmopar59
yea definitely more details... why would you ask us to email you?? on a forum you post your question we post our answers you check back to offer and accept knowledge as often as you are able....
Old Oct 17, 2007 | 12:47 AM
minyo16's Avatar
minyo16
dk. sry new at this. i have a 2002 dodge ram 1500 qud cab. 360 5.9. i would also like to know about some gears with both sizes. thanks.
Old Oct 17, 2007 | 07:29 AM
HammerZ71's Avatar
HammerZ71
The higher the lift the more wind drag, the worse the gas mileage, also the larger & heavier the tires, the worse gase mileage. Also, the 5.9 has about 80 or so less horsepower than the Hemi, and yup, gets worse gas mileage. Nothing is going to make a dramatic difference in fuel economy. You need to just make sure it's proper maintained, frequent fluid changes, proper air in the tires, etc. will give you better fuel economy than any aftermarket product you could purchase. After that, you could help it breath a little better with cat back exhaust (if you don't one already) and possibly a CAI.
As far as tires, stay away from 37" tires, our IFS front ends can't handle it. You'll be breaking front end parts all the time if you take it off-road. Besides, your Pro-Comp 6" kit is really only about 5.5" and will not fit 37's without some trimming or other modifications. I believe Skyjacker is still the only 6" kit that will fit 37's without any trimming.
As far as the brand of tires, I've always liked Mickey Thompson/Dick Cepek offerings. The Mickey ATZ's are a great A/T tire. The MTZ's or Cepek Mud Country's are great in mud. The Baja Claw is VERY aggressive and the Cepek Fun Country II is a fantastic tire with features of both an A/T & M/T tread.
Old Oct 17, 2007 | 12:49 PM
atlaticblueram's Avatar
atlaticblueram
"stay away from 37" tires, our IFS front ends can't handle it. You'll be breaking front end parts all the time if you take it off-road."
What does that mean hammerz71 you dont have faith in your truck or ours? I think you are wrong i had 37" tires on my truck for awhile and never broke anything except front hub bearings wearing out have a little faith. 37" tires will not fit with the procomp lift i had a body lift with mine but i recently took it off to fit 35'sand you can get better gas mileage out of the 5.9 i had a supercharger on mine and was getting 16-18 mpg with 37" tires i also had 4.56 gears.
Old Oct 17, 2007 | 02:13 PM
minyo16's Avatar
minyo16
if i put 4.56 gears immy truck that would give me woers gar mpg i thouhgt? and if i put them in can i still got over 65mph
Old Oct 17, 2007 | 02:23 PM
tdmopar59's Avatar
tdmopar59
you can still go plenty over 65... lower gears compinsate for bigger tires...
Old Oct 17, 2007 | 05:52 PM
manogmin's Avatar
manogmin
your final drive ratio involves your rear end ratio and tire size, for instance, and this is just an example not sure on the numbers. you can have 4.56 and 35's or 4.10 and 33's and have about the same drive ratio, so no real differene in mpg, also stands up to the weight of larger tires better, bigger gears that is.
Old Oct 17, 2007 | 06:29 PM
minyo16's Avatar
minyo16
should i got with 4.11 like the site says for to save gas, or go with the 4.88 for best all around for 37's and what do you guys think about the gears for 35's? http://www.4wheelparts.com/gear_ratio.html sry new at the truck thing just need a lil push the right way with this lol. dont want to lose money
