Lights in gauges in dash on 05 ram
Old Feb 8, 2009 | 12:43 PM
marcusam99's Avatar
marcusam99
Default Hey Thanks
Your instructions and pics on the removal of my instrument cluster were right on. I had disassembled and reassemblem in just under an hour. Has anyone tryed the Sharpie thing with the bulbs?? If so what color and how did it turn out??
Old Feb 9, 2009 | 08:28 AM
MACNKAT's Avatar
MACNKAT
I've done it on the dash of my motorcycle and some people color the LED under the white roller ball of their Blackberrys...works pretty good. Red and Blue seem to stand out the most.
Old Feb 9, 2009 | 10:58 AM
Redone4x4's Avatar
Redone4x4
If I was going through the trouble, I would just put in new colored bulbs. The blue would look pretty cool. I would be concerned with the sharpie wearing or burning off or something. Im trying to think, In mine I also think there is a green light over the cupholder? Keep us posted if you do it, and what bulbs you use if you replace them.
Old Feb 9, 2009 | 11:00 AM
John  M's Avatar
John M
If the stock bulbs are white it means the teal color is coming from within the gauge face. That means your resulting color will be teal + whatever you color the bulb.
Keep that in mind before you start coloring bulbs.
Old Feb 9, 2009 | 11:12 AM
Alldead's Avatar
Alldead
Can anyone confirm the color of the bulb on '06? Is the panel colored teal or the bulb?
Old Feb 10, 2009 | 10:05 AM
Alldead's Avatar
Alldead
Checked it out and, yes, the numbers and ticks in the gauges are an opaque teal color. I didn't pull the panel apart yet so I am not sure if the coloring is a seperate sheet that can be plucked off.
Old Mar 13, 2009 | 07:04 PM
jcanderson08's Avatar
jcanderson08
So my question is, is this procedure about the same for the 2003 ram 1500? im wanting to replace all my bulbs with blue/white bulbs because i have interior and exterior blue LED/neons and the green panel lights are just throwing it all off
Old Jan 18, 2011 | 11:30 PM
itsahemi4x4's Avatar
itsahemi4x4
All bulbs are clear. The sharpie trick does work, but the red needles may be dim. They'll be lit, but dim if you use colored bulbs. The led bulbs are part number b 8.5 from Superbrightled.com. There is a teal opaque film behind the white face that is why the numbers are the ugly green from the factory. I will be doing blue leds when I have the money, but for now, the sharpie trick looks a lot better.
Old Jan 19, 2011 | 12:13 AM
Marx's Avatar
Marx
have a look at this
https://dodgeforum.com/forum/3rd-gen...-led-dash.html
also this thread is so old lol
Old Jan 19, 2011 | 09:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
yeah, really old.
