Which tuner?
Old Oct 23, 2007 | 03:34 AM
MinatorHemi8's Avatar
MinatorHemi8
Default Which tuner?
Ive lost most of the threads I read onprogrammers throughtout the maze of posts so which one should I get for an 06 Hemi.
Im only changing out the headers, air intake to a K&Nand adding a Flow masterdual exhaust kit.
Old Oct 23, 2007 | 08:08 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: Which tuner?
You have 2 choices. Either the Superchips or the Bully Dog Power Pup. Both do the same thing as far as programming. The plus of the SC is that it makes the shifting a little firmer than the BD and it is quicker for the truck reprogramming. The advantage of the BD is that you can find it around $150 cheaper (when buying new) and the computer updates are easier to deal with as you will have a program running on your computer looking for the updates, automaticllay updating and letting you know when there is an update.
Old Oct 23, 2007 | 08:33 AM
tdmopar59's Avatar
tdmopar59
ive heard good things about both... just going by what i hear i would go with the flashpaq but if L and R likes his and its cheaper.... y not!
Old Oct 23, 2007 | 08:19 PM
MinatorHemi8
Reading up on the superchips programmer it says it "can" save my factory settings, I figured the settings could just be reset and were still stored in my computer and does it give you an option to save them or can you inavertandtly erase fac settings..
What im getting at is if I save my factory settings on this superchips programmer and say I drop it and it breaks, Im SOL if I need warranty work and cant reset it and they void my warranty. Or are the F. settings stored in the truck so I could just purchase a new one if they cant repair it plug it up and auto reset my fac settings?
Old Oct 23, 2007 | 08:36 PM
SWOS Chief's Avatar
SWOS Chief
It actually loads the factory settings from the truck onto the flashpaq before allowing you to make change, so "can" equates to "does". Just did it with mine last week.
Old Oct 23, 2007 | 11:14 PM
lewpuckett's Avatar
lewpuckett
both are good but i personally prefer the superchips.
