Coil Springs
Old Oct 23, 2007 | 09:53 AM
Lama's Avatar
Lama
Default Coil Springs
What is the difference between the front suspension on my 05 Hemi Ram Q.C. 1500 4x4 and my friends 06? (same truck)
His front shocks are inside coil springs and I don’t have coils springs, just the shocks.
What’s the difference between the 05 and 06 front suspension?
Old Oct 23, 2007 | 10:48 AM
HammerZ71's Avatar
HammerZ71
Default RE: Coil Springs
You have a torsion bar, he has coil springs. The following definitions are from Wikipedia online encyclopedia:
A torsion bar suspension is a general term for any vehicle suspension that uses a torsion bar as its main weight bearing spring. One end of a long metal bar is attached firmly to the vehicle chassis; the opposite end terminates in a lever, mounted perpendicular to the bar, that is attached to a suspension arm, spindle or the axle. Vertical motion of the wheel causes the bar to twist around its axis and is resisted by the bar's torsion resistance. The effective spring rate of the bar is determined by its length, diameter and material.
The main advantages of torsion beam suspension are durability, easy adjustability of ride height, and small profile along the width of the vehicle.
In most torsion bar systems, especially Chrysler's, ride height (and therefore many handling features) may be adjusted by bolts which connect the torsion bars to the steering knuckles and require nothing more than crawling under the car with a wrench in hand.
A Coil spring, also known as a helical spring, is a mechanical device, which is typically used to store energy and subsequently release it, to absorb shock, or to maintain a force between contacting surfaces. They are made of an elastic material formed into the shape of a helix which returns to its natural length when unloaded. Coil springs are a special type of torsion spring, the material of the spring acts in torsion when the spring is compressed or extended.
Many types of coil spring are wound in an annealed (soft) condition and then tempered to achieve their strength as a spring. Over time, this tempering can be lost and the spring will sag because it can no longer withstand the loads applied.
Old Oct 23, 2007 | 11:18 AM
tdmopar59's Avatar
tdmopar59
uh oh hammer... are you goin down hankL street!!
Old Oct 23, 2007 | 12:37 PM
HammerZ71's Avatar
HammerZ71
Not at all, and shame on you for even making the insinuation! [:@]
It was simply easier to cut and paste than to type! and I had to give credit lest I be accused of plagiarism!
Old Oct 23, 2007 | 12:53 PM
tdmopar59's Avatar
tdmopar59
lol true....!
Old Oct 23, 2007 | 01:51 PM
Lama's Avatar
Lama
Thanks for the excellent explaination.
