Door seal issue - 05 Quad Cab
Old Oct 23, 2007 | 02:40 PM
SilverRam05's Avatar
SilverRam05
Default Door seal issue - 05 Quad Cab
Hey guys, wanted to find out if anyone else here has experienced this problem. On both front doors, the front edge of the door is digging into the door seal when I close it. It's nearly ripped the driver's side all the way through and the passenger side is on its way. Anyone have any insight? I have no idea how this design ended up in production, or if this is just MY truck.
Thanks for any help
Old Oct 23, 2007 | 03:08 PM
dg2003's Avatar
dg2003
Default RE: Door seal issue - 05 Quad Cab
No insight or ideas but can confirm it's happening to my '03 as well. When I first noticed it I thought the same thing, 'what kind of goofy design is this'? I keep mine moist with silicone, but don't really use the truck that much so it hasn't really ripped yet, but can definitely see how it happens.
Old Oct 23, 2007 | 04:03 PM
SilverRam05
Thanks....someone on BITOG directed me to a TSB online.
Old Oct 23, 2007 | 04:14 PM
Tailbuster's Avatar
Tailbuster
There is a TSB for this. Your local dealer should upgrade them to the new design
Old Oct 23, 2007 | 04:16 PM
CarGuyOhio's Avatar
CarGuyOhio
They will only replace if you are still in warranty.
Make sure they put on the new design and no the old one. I have them on both my 04 SRT and 05 Hemi, I will snap a pic when I get home so you can see the difference.
Old Oct 23, 2007 | 06:47 PM
CarGuyOhio's Avatar
CarGuyOhio
The new design, I think they started using these in 06 models.
[IMG]local://upfiles/15402/4C3AC9C5801C4A84AE2421B890D7B528.jpg[/IMG]
Old Oct 23, 2007 | 07:50 PM
moparmutt's Avatar
moparmutt
Mine is tearing too. Looks like I need to go to the dealer and see if I can get this new molded rubber seal.
Old Oct 23, 2007 | 08:25 PM
Jzero69's Avatar
Jzero69
FYI.... There is also a TSB on the bottom weather stripping I know atleast on my 04 2500 where it doesn't come up enough on the side and mud, dirt, water gets up past it in the bottom of the door. There is a new design that comes up higher to fix this.
Old Mar 30, 2009 | 10:38 PM
AidansHemi's Avatar
AidansHemi
TSB 23-049-05 gives p/n's for improved secondary door seals
Old Mar 30, 2009 | 10:41 PM
jonnymagnum's Avatar
jonnymagnum
ya, my passenger side is ripped....
