Alarm Question
Old Oct 24, 2007 | 07:07 PM
Dodge Leaks's Avatar
Dodge Leaks
Default Alarm Question
Some of you may have read my post (accidently put on 2nd Gen) about the attempt to steal my 2006 1500.
The truck was in my driveway, under a streetlight. The thieves punched the door lock, and ripped out the ignition. They could not start the truck because of the electronic key ignition, but they did $2,200 worth of damage.
I asked the shop if I had incorrect programming, and should the panic alarm (horns honking) have kicked in when the door was opened without a key. He told me that if they had forced a screw driver into the lock and turned it the alarm would go off, but since they just punched the lock through and broke it that the alarm would not work.
How does that story sound to you?
Second question, I am thinking about a LoJac, but want to consider; a LoJac is silent but locates the stolen car. If they can't get my truck because of the electronic key would it be better to just have a disturbance alarm and maybe they won't do so much damage. Oppinions?
NNY
Old Oct 24, 2007 | 08:34 PM
dieseldoc1's Avatar
dieseldoc1
Default RE: Alarm Question
unless u ordered it with an alarm it most likley has none. the horn honk when u lock the doors is just that, a horn honk. my 06 mega cab sameway. open the doors and nothing happens. so i added a mopar evs-1 alarm system. works with ur current fob and chip in key system. adds starter kill,horns go nuts if broken into or window broken as it also adds shock sensors. about 180 bucks. installed my self in a afternoon. more peace of mind. note: will not work with mopar remote start.
Old Nov 3, 2007 | 10:07 PM
Dodge Leaks
The truck is back after two weeks. End result $2,300 worth of damage. I had an EVS I installed, and it seems to be working well except the parking light flash doesn't happen when arming.
There are times I'd like to lock the doors without arming the system, does anyone know how to work this without going into valet mode?
GJ
Old Nov 3, 2007 | 11:50 PM
prerunner's Avatar
prerunner
The factory alarm will arm no matter what!!!!! The only way to cancel out the alarm is to put it in Valet!!!! Either use the switch installed or put the key in the ignition and turn it to the on position 3 times within 10 seconds.
