steering squeel
Old Oct 29, 2007 | 09:17 AM
fire10's Avatar
fire10
Default steering squeel
My 05 Ram 1500 QC has developed a great squeel when I turn the wheel.
It doesnt sound like the need you get at full lock, its more high piched and i hear it the most when
I am driving at low speeds in tight areas (parking lots)
It has 51,000 miles on it.
Any one have any ideas on how to fix it.
Old Oct 29, 2007 | 09:30 AM
abarmby's Avatar
abarmby
Default RE: steering squeel
Yep, sounds like an accessory belt slipping on your power steering pump.
Check your serpentine for wear and/or slipping.
Have you driven through a lot of water recently?
Either clean it using a spray you can get for cleaning and removing grease and dirt deposits fromthe belt, or replace it.
Try the spray first. If it doesn't work, check the belt for wear such as cut edges and belt threads splitting off the sides etc.
Al.
Old Oct 29, 2007 | 10:38 AM
tdmopar59's Avatar
tdmopar59
yea the belt is starting to slip with the added stress from the power steering pump... change the belt and check your power steering fluid....
