Superchip
Help, I have just purchased a Superchip and hooked it up to my 2003 Dodge Ram 1500 Hemi. It gave me a diagnostic code of P0138 which translates into 2 sensors bad according to Advance Auto at an approx. cost of $200.00 for parts. Is this necessary or is this just a common problem with the chip?
Reset your truck back to factory settings and see if the code still exists. If so then the problem can be solved by forking out the money for the sensors. If the code does not exist try reinstalling your flashpaq again. If you get the code again then there is something wrong between your flashpaq and your truck. Try with it still installed disconnecting the battery for about 10 minutes to reset the system and see if this helps. Keep us posted.
