gear lube in manual trans and diff
Old Oct 31, 2007 | 01:30 PM
hetkind's Avatar
hetkind
Default gear lube in manual trans and diff
My 07 RAM 1500 is about to hit 15k on the clock and time for a major service...
Mobil 1 anda wix filter for the engine
Now the transmission comes stock with ATF (it is a six speed gertag), and historically, I put premium 80w90 GL-5 gear lube in (prefer the Citgo brand JT7 or something like that). Do I need to stick with the crazy ATF or can I use normal gear lube, like every other manual transmission vehicle I have owned or ever owned.
And for the differential...it is the normal, NON limited slip, the other two dodge trucks in the yard have the old 8 and 3/4" limited slip rear ends and they are bullet proof.The new truckhas some crazy light weight oil, again, any problems with using normal 80w90 GL5 gear lube?
The last 5 gallon bucket of gear lube was $72, big jump in the last few years, can still find the cheap stuff at TSC or Walmart for $25 a bucket, but it tends to blow out of the breathers in heavy use.
Thanks so much,
Howard
Old Oct 31, 2007 | 01:48 PM
turbot_bird's Avatar
turbot_bird
Default RE: gear lube in manual trans and diff
Stick with the atf, my bird with a t5 takes atf too.
Old Oct 31, 2007 | 03:45 PM
Drew's Avatar
Drew
yup. . .ATF in that tranny. . .your axels need 75-90 GL-5. dont worry about friction modifyer if you have a LSD, the AAM axels do not use clutches.
Old Nov 1, 2007 | 05:21 AM
HankL's Avatar
HankL
I can't remember all the details but there was a past post where a Ram owner complained of the Getrag not shifting to his liking, and about using the same synthetic gear oil BMW recommends for use in their Getrags.
Old Nov 1, 2007 | 07:41 AM
hetkind's Avatar
hetkind
We have four BMW motorcycles with the Gertag transmissions, and they all use the GL-5 80w-90 gear lube. I believe the ATF in the manual transmissonis to increase fuel economy for CAFE figures, but does not give maximum transmission life.
Howard
