Wrong gear lube?
Old Nov 1, 2007 | 12:19 AM
JD1500's Avatar
JD1500
Default Wrong gear lube?
I went by my window sticker, and that and my build sheet disagree. but i already did my first rear end change.
will i do any damage running the weight/viscosity and friction reducer in my non LSD rear end? i am going to jack it up tis weekend and check to be sure, but jsut curious now as to any problems.
also, if i jack it up and turn one wheel. both turning same=LSD and turning opposite=open correct?
Old Nov 1, 2007 | 01:00 AM
turbot_bird's Avatar
turbot_bird
Default RE: Wrong gear lube?
non lsd both will spin opposite directions, lsd- both will spin same direction. adding the modifier in a non lsd wont do any harm
Old Nov 1, 2007 | 08:19 AM
LoFlyer's Avatar
LoFlyer
The friction modifier reduces the HP (high pressure) properties of the gear oil. I think that is a partial cause of the LSD failures. Lower HP properties = Higher temps. No big hurry but I"d rec you change theoil when convenient for you andreplace with 100% gear oil.
