Any one useing a Brite Box?
Old Nov 3, 2007 | 07:24 PM
1Normy's Avatar
1Normy
Default Any one useing a Brite Box?
I have a 2004 Ram and I am considering adding a brite box/fogster kit with the bulbzilla upgrade. I called them and they also offer it with a slave wire output for auxilary lighting relays as well. Is any one using this and if so how do you like it, and have you had any problems? I live in Northern British Columbia and have to be on the lookout for the likes of Yogi, Bambi, Rocky & Bullwinkle, not to mention days are short here in the winter months!
Old Nov 3, 2007 | 08:34 PM
squirtbottle09's Avatar
squirtbottle09
Default RE: Any one useing a Brite Box?
I had a brite box on my ford and loved it. What is the bulbzilla upgrade? Does it just change out the wiring for larger more powerfull lights.
Old Nov 3, 2007 | 08:49 PM
1Normy's Avatar
1Normy
Here is the link:
http://www.innovadd.com/bulbzilla.fogzilla.mod.html
Old Nov 3, 2007 | 08:50 PM
cmoschip's Avatar
cmoschip
I am and I love it. PM me and I'll shoot you some pics, although it's hard to judge much of anything by pictures, huh?
Bulbzilla upgrade allows you to use 9005 bulbs in the fogs instead of the factory 9006s. The 9005 lights put out more lumens of light.
Here's the info.
I have the stage III+ builbzilla and don't regret it for a moment. Combined with the Hella 500's it makes things VERY visible. No hassles with HID kits that are difficult toinstall and can be problematic. No wiring problems - it's all plug and play.
Old Nov 3, 2007 | 09:13 PM
dhvaughan's Avatar
dhvaughan
i have a brite box with standard bulbs. i love it.
Old Nov 3, 2007 | 11:20 PM
1Normy's Avatar
1Normy
Also have any of you seen head light life deminish becausse of using them?
Old Nov 22, 2007 | 08:18 PM
Patriot_RAM's Avatar
Patriot_RAM
I boughta set of the Brite Boxes with FLC for my RAM. The first one melted over the summer. The second one melted tonight on the way home. I HIGHLY recommend against them unless you want your truck to burn up. Want to see a video?
http://www.cyber3dnet.com/truckpics/MOV04639.MPG
Here are some photos:
Old Dec 14, 2007 | 03:03 PM
motorhead426's Avatar
motorhead426
I wonder if the fuse was too large? i just melted my headlight connector last week with aftermarket bulbs, let alone running both the high beam and low beam together. I'm going to have to devise a way to keep wires from burning up... maybe a circuit breaker is in the works.
Old Dec 14, 2007 | 03:14 PM
djr04's Avatar
djr04
There's a lot of guys running 9005's in the fogs without any aftermarket parts. All that you need to do is trim the top tab a bit, remove the plastic prongs inside the bulb connector, and add an extra gasket for a tight fit. However, I'd recommend researching this a bit before anyone tries it, those 9005's pull more wattage than the 9006's. 65W vs. 55W [/align]
