My spedometer is lying to me.
Old Nov 9, 2007 | 05:30 PM
United1's Avatar
United1
Default RE: My spedometer is lying to me.
OK, as I re-read what I said, it did not make sense. Dis-reagard the whole no difference thing I said above (thanks playername for setting me straight, spud were in the same boat).
Old Nov 9, 2007 | 09:40 PM
Parts/Service's Avatar
Parts/Service
PM me your VIN and I will tell you what tires came on your truck from the factory....
Old Nov 9, 2007 | 09:44 PM
HemiLonestar's Avatar
HemiLonestar
It happens, the door sticker on my 03 reflects the 17" wheel/tire combo for the vehicle. The build sheet from the factory lists the 20" wheels the truck came with.
Old Nov 9, 2007 | 10:10 PM
ScottJ175's Avatar
ScottJ175
ORIGINAL: Parts/Service
Already got my build sheet so I know it got the 265s https://dodgeforum.com/m_1036811/tm.htm
What I'm confused about is why the door jamb sticker from the factory doesn't reflect that.
My last 8 are 3S225842. If you could pull and shoot a service history to me in e-mail or PM I'd appreciate it. I forgot to ask this morning when I picked up the reflector for the passenger door this morning.
Old Nov 9, 2007 | 10:34 PM
MikeHTally's Avatar
MikeHTally
Larger (265s) are larger in diameter. This also reduces your effective rear axle ratio. My 3.55 rearend is changed to 3.43 with the 265s on it from stock 245s. This is why radical changes in tire size (larger) cause the truck to have no low end guts and worse city mileage. Highway mileage improves slightly due to fewer engine rpm at a given road speed. The speedo and odo will read slightly low as well. This site has some cool calculators to answer some questions: http://www.wallaceracing.com/Calculators.htm
Old Nov 9, 2007 | 10:38 PM
JimmyDiablo's Avatar
JimmyDiablo
navagation will give you a accurate reading.
Old Nov 9, 2007 | 10:40 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
The dealer or anyone with a good scanner and current software can set your pinion factor to correct for the new tire size.
Old Nov 10, 2007 | 08:17 AM
BanksPwrHemi's Avatar
BanksPwrHemi
The door jam only lists what is the standard tire configuration for the truck. They do not have different stickers for all the possible tire combinations from the factory. The other size tires are listed in the owners manual. The vehicle should be ECU's should be coded to reflect the installed options. If yours is wrong then the wheels were changed out after the truck came off the production line with the wrong size tires by accident. The other possiblity is the dealer had a customer that wanted the larger tire on another truck on the lot and they swapped them. This happens quite a bit, usually for the 20's though.
Old Nov 10, 2007 | 08:51 AM
ScottJ175's Avatar
ScottJ175
ORIGINAL: BanksPwrHemi
Thanks. That's what I was wondering. The Audi's door jamb sticker lists every combination available from the factory (only 2 I think).
The American Generals on there are fairly new so I'm guessing that when it came time to replace the factory tires someone just read the door sticker and put those on there.
Now I have to decide if I want to go back to the original 265 size and sell the 245s on eBay or just have the computer calibrated. I'm tempted to go all the way to 32s since they'll fit but this isn't a serious off roading truck. I have my CJ for that. This truck's job is to tow and haul stuff and be able to get me down some muddy trails to go hunting.
Old Nov 10, 2007 | 09:09 AM
pilot00's Avatar
pilot00
I could be wrong but I do not think this is true. 245/70/17 is standard on the rams. Would someone with factory 20 inch rims look at the door sticker and tell us what it says. My inlaws had a chevy truck just like mine but I had a different 4X4 package on it so we had different sized tires. The sticker reflected the correct different tire size on both trucks.
I bought my 2006 truck used ( 8 mo old). The sticker showed 17 inch rims but the truck had brand new 20 inch rims and tires. I asked the dodge dealer about it and they said they swaped the tires off to help it sell better. I had the original 17 inch tires put back on because the tiresare cheaper to replace and there are more choices of tires to replace them with (mud tires).
