07 Emblems
Does anyone know if the HEMI and Dodge 1500 emblems on the side are on with just tape or do they have the push tabs into the sheet metal?
I want to remove them but not until I know.
Thanks
Thanks
stuck on with tape. if your trying to remove them a good trick is to heat up lighty with heat gun to get the glue tacky ( not too much heat dont want to ruin paint) then spray wd-40 onto fishing line and the emblems and lightly saw behind the the letters. it works pretty good. im sure there is an easier way but thats the advice i got on here andit was really good.better to do it in the summer. just be patient it can take a while
I took off all my emblems and the side molding off my truck in about 20 minutes. I just heated up the emblems and pulled them off, then I bought a little wheel (enamel or rubber) somthing like that from an outo paint store and put it on my drill and all the glue came right off it was really easy. The wheel i used was yellow so if u had a dark colour truck i dont know how good it would work as it might leave some yellow marks but it worked fine on mine truck but its silver.
What about the Ram emblems on the grill cross hairs and tailgate? Same thing? No holes when I take them off right? Putting the duck on the hood and trying to stick with the blacked out theme, hard to do with a chrome emblem on the front and rear.
Trending Topics
the dodge head on the tailgate is just double sided tape....as for the dodge head on the grille...i believe that one has a hole behind it, but i can't remember for sure...i read a post once, like 1 1/2 yrs ago about taking it off but can't remember exactly.
