Cleaned out my throttle body today...
Old Nov 15, 2007 | 07:04 PM
  #21
brucewayne3891's Avatar
brucewayne3891
Default RE: Cleaned out my throttle body today...
Also, if any of you HEMI owners get a p2175 check engine light code, TAC: System low airflow like I did, clean your throttle body and clear the code and that takes care of the problem. Getting a throttle body spacer and being able to hear the air go through the throttle body helps. The cleaner the whistle, the cleaner your throttle body is.
Old Nov 15, 2007 | 10:47 PM
  #22
Hessmonster's Avatar
Hessmonster
I used Seafoam in mine sucke it through the vacuum line from the brake booster. Man did it smoke like a James Bond car. After the smoke cleared it did idle smoother and seemed a little more snappy. Just my 2 cents.
Old Nov 15, 2007 | 11:11 PM
  #23
loiler921's Avatar
loiler921
yes seaform is great
Old Nov 15, 2007 | 11:19 PM
  #24
hemivec's Avatar
hemivec
ORIGINAL: brucewayne3891
i know that one it came back the other day just hope i get time over the next day or two to get it done with the honey do list i got aswell she want the christmas lights up this weekend
Old Nov 16, 2007 | 07:40 AM
  #25
HankL's Avatar
HankL
A lot of the crud
is coming OUT of the engine
because of the EGR system.
I am in favor of periodic cleaning
but don't be surprised if the MPG drops slightly
for a little while after a carbon cleaning.
The same cleaning stuff that cleans the carbon off the throttle body blades
and removes crud from the back sides of the intake valves (improves max airflow) will also remove carbon deposits from inside the combustion chamber and reduce the 'real world' compression ratio. This drop in CR hurts fuel efficiency slightly until the carbon deposits build back up.
