sub box and woofer?
Old Nov 14, 2007 | 09:42 AM
hps3's Avatar
hps3
Default sub box and woofer?
I have a JL W3 10" in an up facing box under the pass rear seat. It is on a MTX 3001 amp. I dont know if it is the box or the amp but it doesnt sound good. It doesnt get much bass and when I turn the volume or the gain up the woofer bottoms out or begins to pop. does anyone else have this problem? I saw someone with a downfiring box which sounded awesome. would this be my answer...
Old Nov 14, 2007 | 09:51 AM
The Peddler's Avatar
The Peddler
Default RE: sub box and woofer?
Is your speaker still good, sounds like it might be blown.
Old Nov 14, 2007 | 01:28 PM
Abqhemi's Avatar
Abqhemi
yeah check the speaker but mine is the same configuration and it sounds fine.
Old Nov 14, 2007 | 03:00 PM
casper3380's Avatar
casper3380
+1
Make sure you arent over boosting too. But burned out woofer sounds right.
Old Nov 14, 2007 | 05:21 PM
Ben D.'s Avatar
Ben D.
depends on enclosure as well. IMO the stuff under the seats don't have enough room for a sub to perform very well. a w3 needs a decent sized enclosure as well. could be ur amp as well. is the sub frozen in place watch it when ur playing stuff is it moving normally??
Old Nov 14, 2007 | 07:16 PM
casper3380's Avatar
casper3380
the w3 requires .625 cu ft sealed per jl audio, that enclosure is .65, shouldnt be the box. How old is the subwoofer, is it broken in properly?
Old Nov 15, 2007 | 09:14 AM
hps3's Avatar
hps3
I checked the woofer and its fine. I even tried a pioneer shallow mount.
Old Nov 15, 2007 | 09:17 AM
The Peddler
Check out your amp!
Old Nov 15, 2007 | 09:47 AM
tdmopar59's Avatar
tdmopar59
check your wires as well.. make sure nothing got screwed up!
