3rd Gen Automatic Trans gear ratios?
Old Nov 15, 2007 | 10:40 PM
nvisciani's Avatar
nvisciani
Default 3rd Gen Automatic Trans gear ratios?
Anyone have or know where to find what the 3rd Gen Automatic Trans gear ratios are?
Old Nov 15, 2007 | 11:17 PM
loiler921's Avatar
loiler921
Default RE: 3rd Gen Automatic Trans gear ratios?
haynes manual. u should get one
Old Nov 16, 2007 | 12:59 AM
hemiyellow's Avatar
hemiyellow
DC Insider
download the manual....
1st . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.00:1
2nd. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.67:1
2nd Prime . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.50:1
3rd . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.00:1
4th . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.75:1
5th . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.67:1
Reverse . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.00:1
Old Nov 16, 2007 | 01:58 AM
nvisciani's Avatar
nvisciani
hemiyellow - thanks!
Slick ride!
Old Nov 16, 2007 | 08:00 AM
HankL's Avatar
HankL
archived Ram transmission info that might be of use to someone:
September 1 is DC press kit day, and they are already revealing the
January 2007 6.7 liter Cummins for the pickups will be rated at 350 hp @
3000 rpm (it actually says 3013 rpm) and 650 lb-ft @ 1500 rpm. The 68RFE
will also be available at the same time.
Ready for the kicker?
The engine is de-rated for the *MANUAL* transmission - only 610 lb-ft. @
1400 rpm... the total opposite of the second-gens.
Engine is 408 cid, 6690cc. Bore and stroke is 4.21 x 4.88.
68RFE ratios:
1 - 3.231:1
2 - 1.837:1
3 - 1.410:1
4 - 1.000:1
5 - 0.816:1
6 - 0.625:1
R - 4.444:1
G56 carries over unchanged. Current 325/610 5.9 liter engine and 48RE
automatic end production in December, last orders will likely be
November 1st, give or take.
As previously announced, the 3500 chassis cab will be rated at 305/610
for both the G56 and the Aisin AS68RC automatic.
Aisin ratios:
1 - 3.74:1
2 - 1.96:1
3 - 1.34:1
4 - 1.00:1
5 - 0.77:1
6 - 0.63:1
R - 3.54:1
No changes to axle ratios... just the 3.73 and 4.10 diffs.
Any questions on any of the 2007 Rams, just ask... I have the kits already.
KC Jackson
2005 Ram 3500 DRW Quad 4x4 SLT Cummins--------
For those not aware, the venerable New Venture (now once again New
Process) NV5600 6 speed manual will be replaced sometime during the 2004
model year by the Getrag G56. The two key aspects of the G56 are:
- lower overall weight thanks to an aluminum case (compared to the
incredibly heavy iron case of the NV5600)
- higher power input
The ratios of the new G56 are a tad lower than the 5600 as well - the
5600 number is first, then the G56:
1st - 5.63 - 6.29
2nd - 3.38 - 3.48
3rd - 2.04 - 2.10
4th - 1.39 - 1.38
5th - 1.00 - 1.00
6th - 0.73 - 0.79
Rev - 5.63 - 5.74
This new 6 speed will also replace the NV4500HD used with the Hemi in
the 2500, 3500, and Power Wagon models.
The 1500 will also gain a Getrag 6 speed manual, this is the model 238
used with the 3.7 V6 and 4.7 V8 (no manual offered with the 1500 Hemi)
1st - 4.23
2nd - 2.53
3rd - 1.67
4th - 1.23
5th - 1.00
6th - 0.79
Rev - 3.84Transmission:
NV4500/NV4500HD - Manual, Five-Speed Overdrive
Availability: NV4500 - standard with 5.7-liter V-8 and 8.0-liter V-10 engines
NV 4500 HD - standard with 5.9-liter standard output I-6 diesel
Description: Synchronized in all gears
Gear Ratios:
1st: 5.61
2nd: 3.04
3rd: 1.67
4th: 1.00
5th: 0.75
Reverse: 5.04
Overall Top Gear Ratio: 2.80 with 3.73 axle ratio and 3.07 with 4.10 axle
ratio
Transmission: NV5600 - Manual, Six-Speed Overdrive
Availability: Standard with 5.9-liter high-output I-6 diesel engine
Gear Ratios:
1st: 5.63
2nd: 3.38
3rd: 2.04
4th: 1.39
5th: 1.00
6th: 0.73
Reverse: 5.63
Overall Top Gear Ratio: 2.72 with 3.73 axle and 2.99 with 4.10 axle
Transmission: 545RFE - Automatic Five-Speed
Availability: Optional with 5.7-liter engines
Description: Three planetary gear sets, one overrunning clutch, full
electronic control, electronically controlled converter clutch
Gear Ratios:
1st: 3.00
2nd: 1.67 - upshift; 1.50 kick-down
3rd: 1.00
4th: 0.75
5th: 0.67
Overall Top Gear 2.50 with 3.73 axle and 2.63 with 4.10 axle
Transmission: 47RE/48RE - Automatic, Four-Speed Overdrive
Availability: 47RE - Optional with 8.0-liter V-10 and standard-output Cummins
diesel engine
48RE - Optional with 8.0-liter V-10 and standard-output Cummins diesel engine
Description: Hydraulic control, electronically controlled governor overdrive,
overdrive lockout and converter clutch
Gear Ratios:
1st: 2.45
2nd: 1.45
3rd: 1.00
4th: 0.69
Overall Top Gear Ratio: 2.57 with 3.73 axle ratio and 2.82 with 4.10 axle
ratio
Transfer cases: NV271/NV273
Availability: NV271 - Standard 4WD ST
NV273 - Standard 4WD SLT Plus
Type: Part Time
Operating Modes: 2WD; 4WD High, Locked; Neutral;
4WD Low, Locked
Shift Mechanism: NV271 - manual, NV273 - electric
Low-Range Ratio: 2.72
Center Differential: None
Dave Fritz's table at:
http://www.dodgeram.org/tech/transmission/4xrh.htm
Mercedes-Benz transmissions used in:
ML230
ML320
ML430
ML55
ML270CDI
ML270CDI
5 sp manual
5 sp auto
5 sp auto
5 sp auto
5 sp auto
6 sp manual
transmission type designation
GL76/29B-5
W5A330
W5A 580
W5A 580
W5A 580
NSG 370 *
max. torque input
202 lb / ft
275 Nm
242 lb / ft
330 Nm
426 lb / ft
580 Nm
426 lb / ft
580 Nm
426 lb / ft
580 Nm
272 lb / ft
370 Nm
1st
3.856 :1
3.951 :1
3.595 :1
3.595 :1
3.595 :1
5.014 :1
2nd
2.183 :1
2.423 :1
2.186 :1
2.186 :1
2.186 :1
2.831 :1
3rd
1.376 :1
1.486 :1
1.405 :1
1.405 :1
1.405 :1
1.789 :1
4th
1.000 :1
1.000 :1
1.000 :1
1.000 :1
1.000 :1
1.256 :1
5th
0.799 :1
0.833 :1
0.831 :1
0.831 :1
0.831 :1
1.000 :1
6th
0.828 :1
reverse
4.218 :1
3.147 :1
3.167 :1
3.167 :1
3.167 :1
4.569 :1
torque converter ratio
1.85 :1
1.80 :1
1.80 :1
1.80 :1
weight
31.8 kg
76 kg
80 kg
80 kg
80 kg
40.5 kg
previous versions
W 5A 300
W5A 400
(concerning the manual transmissions used in early Dakotas)
Some of the 5-speeds are the AX-15's, which are on the weak side.
However, they share the same bellhousing bolt pattern with many other
transmissions made by Aisin-Warner. The stoutest of which is probably the
R-154 found in the late-80's to early 90's Toyota Supra turbos. They're FAT
transmissions, with a beefy cast iron mid plate that happens to fall very near
where the trans crossmember is in an A-body.
I'm mulling on that swap right now. The Dak bellhousing & flywheel are the way
to do that swap, as it's a near bolt in... once you have the space in the
trans tunnel. FWIW, the 4.7L and 5.7L v-8's have the same bolt pattern on the
back of the block, and even the 3.7L Jeep engine does too. The 6-speed behind
the Jeep Liberty turbo diesel looks interesting (also has the same bellhousing
bolt pattern), but I bet it's not a small trans, either.
Clair
Old Nov 16, 2007 | 11:27 AM
MoparRob's Avatar
MoparRob
Damn could you make your cut and paste shorter next time.... lol
Old Nov 16, 2007 | 03:42 PM
hemiyellow's Avatar
hemiyellow
DC Insider
thats why most of us have him blocked...along with other reasons lol
