gears
Old Nov 18, 2007 | 09:50 PM
herring_jerritt's Avatar
herring_jerritt
Default gears
im thinkin about puttin 3.92 gears in the rear, does anyone have any tips or usefull info on doin that
Old Nov 18, 2007 | 10:05 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: gears
yeah make sure you set it right or you'll have serious problems.... What gears are you switching from?
Old Nov 18, 2007 | 10:06 PM
helopilot's Avatar
helopilot
Default RE: gears
How about 4.56's?
tizzle0469's Avatar
tizzle0469
Default RE: gears
i got a set for mine the other day. i havnt put them in yet but my dad has an 05 ram 4.7 and he had stock gears and went up to 3.92's and could tell a big difference. then he put the heavy *** stock 20's on it and lost the get up. im planning on runnin the 3.92's with my stock 17' alloys and should pep up quite a bit.
Old Nov 18, 2007 | 10:17 PM
MoparRob's Avatar
MoparRob
Default RE: gears
This is a pretty good chart showing gears VS. tire size I know most of these guys here would recommend 4.10s or even 4.56s..... http://www.4wheelparts.com/gear_ratio.html
herring_jerritt
Default RE: gears
which gives u more acceleration? the higher gears or the lower ones?
Old Nov 18, 2007 | 10:28 PM
MoparRob's Avatar
MoparRob
Default RE: gears
The higher the number the lower the actual gearing is the more torque/acceleration you will have..
Old Nov 18, 2007 | 11:05 PM
HammerZ71's Avatar
HammerZ71
Default RE: gears
If you are going to do it, do it right. 4.10's for non-towing applications with standard size tires up to about 33's. 4.56's for towing or any tires over 33".
Old Nov 19, 2007 | 12:23 AM
oefootball_70's Avatar
oefootball_70
Default RE: gears
I am going to be running 34.1 inch tires after christmas and was wondering how much it would cost me to get new gears installed. And how long I can drive on the gears I have now.
Old Nov 19, 2007 | 12:28 AM
tdmopar59's Avatar
tdmopar59
Default RE: gears
ORIGINAL: HammerZ71
+1
you could run on stock gears oefootball its just gonna chug more gas and have less pickup...
