excessive fluid(water) drainage
Old Nov 20, 2007 | 10:32 PM
exRX8's Avatar
exRX8
Default excessive fluid(water) drainage
Hey folks, I noticed this after noon while getting into my truck that there was what looked like a water spot under my truck. My truck hadn't been running for almost 9 hours, so it wasn't A/C drainage. I got home and there was a dotted fluid trail leading into my driveway. I looked under the front passenger area and fairly steady drip was going. The fluid looks like water(no odor or color). I've never seen such drippage from underneath before.Also I noticed in the engine bay the open pipe that sticks out of the firewall on the passenger side was dripping fluid fairly well. It was enough to soak 3 rags that I laid down on my driveway. Is this normal drainage? Can some one just tell me what is going on? Should I be concerned?
Old Nov 20, 2007 | 10:36 PM
herring_jerritt's Avatar
herring_jerritt
Default RE: excessive fluid(water) drainage
i have an 03 and and 06 hemi and i have noticed that the 06 drips mor then any other truck that i have ever owned, but it seems to still work fine, no unusuel noises or anything so i wouldnt worry about it
Old Nov 20, 2007 | 11:28 PM
Pappy_FB's Avatar
Pappy_FB
ORIGINAL: exRX8
Hi exRX8,
Welcome to da forums.
No that ain't normal.
Could you get a picture of the open pipe you speak of?
My wife had a Sundance once that the vent drain would get clogged with normal debris (leaves, insects, etc) It would back up and leak into the passenger floor board. After I would unclog it would drip for what seemed like 10 minutes from the firewall.
Old Nov 21, 2007 | 07:15 AM
MikeHTally's Avatar
MikeHTally
ORIGINAL: Pappy_FB
ORIGINAL: exRX8
Hi exRX8,
That was a common problem with Chrysler products all through the '60s and '70s. The A/C drain line would clog causing the condensation to drain back into the car. That sounds like what you have there, unless you hadn't been running the air conditioner for several days. Do you recall if it collected the "usual" amount of drips after you parked it?
Old Nov 21, 2007 | 08:22 AM
baltech's Avatar
baltech
Do you have a sunroof ? It could be the drain tubes.
Old Nov 21, 2007 | 03:04 PM
exRX8's Avatar
exRX8
I took it in today and the dealership said they couldn't find anything wrong. They blew out the A/C line, and said it didn't appear to be clogged. Neither of us found water on the interior of the car. They said that even though I hadn't run the A/C, running the defrost (which I have been)will show drainage also. The truck is running great, I guess I'll just keep an eye on it. Baltech, I do have a sunroof so where do the drain tubes empty?
Old Nov 21, 2007 | 04:06 PM
kx250frider617's Avatar
kx250frider617
mine dodes the same thing, don't worry about I think its just from condesation from sitting all night
Old Nov 22, 2007 | 01:27 AM
John  M's Avatar
John M
Defrost runs the AC compressor to get dehumidified air even though it doesn't light the AC indicator. That irks some people when they can't disable it so they decided we'd be better off not seeing it lit.
Old Nov 22, 2007 | 08:00 AM
baltech's Avatar
baltech
ORIGINAL: exRX8
I don't know on the ram,but my wifes ford explorer drains out the front wheel wells.
