electric water pump
Old Nov 22, 2007 | 03:57 AM
sa's Avatar
sa
Default electric water pump
i drive an 04 4.7L 1500ram and i'm looking foward on changing my water pump for an electric wondering if anybody has done it and were do they sell it...i cant find one for some reason.....you got any pic on it
have aa gobble gobble good day
Old Nov 22, 2007 | 11:38 AM
tdmopar59's Avatar
tdmopar59
Default RE: electric water pump
[sm=confused06.gif] electric water pump..... maybe an electric fan....
Old Nov 22, 2007 | 12:06 PM
kregier's Avatar
kregier
No, he means electric water pump. I've heard of some people doing this on small cars. I don't know if you can find one big enough for a V8 though.
Old Nov 22, 2007 | 12:14 PM
tdmopar59's Avatar
tdmopar59
hmm thats wierd... i've never heard of them til now...
Old Nov 22, 2007 | 01:57 PM
kregier's Avatar
kregier
Although he could very well mean fan I guess. I just checked and jegs actually carries some for BB and SB chevys. Who knew? Not sure what you'd have to do because of the drive belt though. Mount a pulley that doesn't run anything I guess.
Old Nov 22, 2007 | 09:50 PM
MikeHTally's Avatar
MikeHTally
ORIGINAL: kregier
Good point, some vehicles have a different path when there's no A/C. Maybe the tensioner could deal with it?
Old Nov 22, 2007 | 10:48 PM
topcop38's Avatar
topcop38
electric water pumps are usually used in racing applications. in my years of racing (about 1989-1996) i never used one. the only real benefit is it doesn't take as much power from the engine as its one less pulley the motor has to spin. they don't usually keep the motor any cooler or more efficient just frees up a couple of HP. i really don't see where you would benefit from it and you certainly won't feel it in the seat of the pants. also i don't believe they are recommended for the street.
i think moroso makes them. maybe weiand or edelbrock also. i'd check with them buti don't think thats a route you want to go.
Old Nov 23, 2007 | 07:38 AM
Gone Fishin's Avatar
Gone Fishin
I think you would be money better spent going after an electric fan rather than water pump. I have no doubt you'd have to design it yourself, and custom fabricate for minimal power gain. The fan mod is already out there, and some dyno results to verify power power increase. Do a search here on the forum.
Old Nov 24, 2007 | 01:58 PM
davb673's Avatar
davb673
You might consider removing the fan altogether, changing coolant to this stuff from Evans Engineering: http://www.evanscooling.com/ and running a separate temp gauge.
Old Nov 25, 2007 | 09:11 AM
Max Power's Avatar
Max Power
Electric water pumps are nort reliable for everyday street use. Even the manufacturers of the recomend them for mostly racing applications and occasional street use. I know a TON of guys running hot street cars, and this is one mod almost none of them will tough.
