07 1500 with 2500 springs
Old Nov 26, 2007 | 06:50 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: 07 1500 with 2500 springs
ORIGINAL: XxSilentHawk99xX
Just buy a 2500.
That would be the easiet thing to do... or just grab a shovel... works wonders...
Old Nov 26, 2007 | 10:25 PM
cyclone429's Avatar
cyclone429
CV joints Suck ... You have them on the 1500, the 2500 has the front shocks inside the springs that fit a solid axel, the 2500 dosent have rack and pinion staering, the 1500 has, makes for a nice car, ****ty truck.
As said, unless you have a mega cab ( than you don't need to up grade the springs ) its not worth the effort, unless you get air bags, front and rear.
Old Nov 27, 2007 | 03:57 AM
chriso3wj's Avatar
chriso3wj
LOVE to get a 2500 and when the lease is upI have plans to do so, but thanks for the + and - input....
Old Dec 26, 2007 | 06:09 PM
CPlowing's Avatar
CPlowing
I have a 2004 ram 1500 quad cab hemi80k milesw/ a 1st gen fisher mm plow, and western pro flow2 tail gate sander, i plow large parkking lots and businesses, i have not broken anything on my truck(yet), i put the plow on3 years, ive hit some bumps and stuff but i guess ive been lucky, if you are going to plow more then 10 times a year heavey snow 12+inches, i would have to say that these trucks can do it, but any more then that, id get a beater truck with a plow and sell yours to get a 2500 for next year! just my 2 cents.....
Old Dec 26, 2007 | 08:04 PM
dieseldoc1's Avatar
dieseldoc1
ORIGINAL: 07 Ram TRX4
ORIGINAL: The_Bishop
Unless you have a mega cab 1500, you cannot run 2500 springs in the front of a 1500; the standard 1500 chassis uses torsion bars and the 2500 chassis uses coil springs.
Sorry to burst your bubble.. but starting in 06 the 1500 do use the coil springs.. tho not the same strength.....but they use coils nonetheless.....
my 06 mega has coil springs. remember 07 Ram TRX4 that the 1500 mega has a 3/4 ton frame and running gear,straight front axle,8 lug wheels,and so on.
