WHOA?!!? Where's my gas mileage?!
Old Nov 26, 2007 | 02:22 AM
  #21
BgBluRam's Avatar
BgBluRam
Default RE: WHOA?!!? Where's my gas mileage?!
Cruise definately doesn't help fuel economy unless you are going down hill for many miles.
Old Nov 26, 2007 | 03:30 AM
  #22
thebean's Avatar
thebean
My guess is that you'd see a drastic increase in fuel economy if you set your cruise control or right foot to about 70mph or less rather than 74-76mph. For me it seems like MDS kicks in all 8 cylinders somewhere around 75mph when cruising on a flat stretch of freeway.
Old Nov 26, 2007 | 05:42 AM
  #23
HankL's Avatar
HankL
At a steady 60 mph on a level highway
with less than 5 mph of wind coming from ahead or side
and stock factory tires at 36 psi
a MDS 5.7 V8 4x4 Ram should be able to get 22 mpg
if everything is 'healthy'
even with winter blend gasoline.
MPG will be slightly higher than 22
if wind is at the rear
or if the highway pavement is concrete instead of blacktop.
In city driving
the average of 3 or more tanks
should give about 14 MPG or better.
Old Nov 26, 2007 | 10:04 AM
  #24
chongo's Avatar
chongo
What I have started to do with my CC is when coming to a hill I will hit the accel button 2-3 times - so pcik up another 2-3 mph and then while going up the hill I will hit the decel button 2-4 times - it keeps it at a steady RPM without downshifting. It definetly helps.
Old Nov 26, 2007 | 02:21 PM
  #25
XxSilentHawk99xX's Avatar
XxSilentHawk99xX
haha hellbilly. I find it strange that you had such a large decrease, but then again, pickups in general are never supposed to get very good mileage
Old Nov 26, 2007 | 02:57 PM
  #26
TANKZ400's Avatar
TANKZ400
Man then i'm getting screwed to I average about 15 as well.
With 89 octane what the motor is quoted for.
How many pound's are you guy's running in your tires.
Old Nov 26, 2007 | 06:02 PM
  #27
JD1500's Avatar
JD1500
15 is pretty good. I get 12-15 in town, and 16-19 highway. (19.9 was my best. Cruise control, 65 mph, flat.) my usual highway is 17. towing i geta solid 12 no matter what.
Oh yeah. I run my stock rubbers and smae size toyo ats at 36psi. 40 if i am towing
Old Nov 26, 2007 | 06:12 PM
  #28
HammerZ71's Avatar
HammerZ71
I get just under 14 with daily driving. Mostly 2 lane highways, with some lights. But my heavily modded beast is heavy, the scales at the local waste management has me just a shade under 7000 lbs. with just me in it plus my toolbox has at least 200 lbs. of off-road recovery stuff and welding equipment in it. Being an '04 I also don't have MDS to help the MPG's.
Over-all, I'm pleased with the fuel economy with the suspension lift and 35's plus winch, grille & brush guards, etc. weighing me down...
Old Nov 26, 2007 | 06:35 PM
  #29
Jus Cruisin's Avatar
Jus Cruisin
With my '04 Ram Hemi (4X2 QC), I would get around 14 mixed driving and around 17 highway. I got almost 15 with my new one mixed driving and I think it should be around 18+ on the highway. Hand calc and O/H comuter are nearly the same. My O/H on my diesel was always about 3mpg on the high side. I have less than 500 miles on my '08.
Old Nov 26, 2007 | 08:25 PM
  #30
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
I get about 15-16 in city and about 23-24 on the highway....2wd single cab 17" wheels. What's the best way to use the overhead computer for mpg? Like today coming home from work I reset it going 65 on the highway for around 15 miles...it showed about 24mpg. If I don't reset it it'll only slowly climb up from the city mpg I had earlier...do you guys reset yours a lot?
