04 Hemi rattle at idle under load
Old Nov 22, 2004 | 06:14 PM
mikebol's Avatar
mikebol
Default 04 Hemi rattle at idle under load
I have an 04 Hemi QC 4x2 and it has developed a rattle. When stopped and the truck is in drive (under a little load), there is a rattle that seems to resonate under the passenger seat. I remember seeing something similar to this in another post where the cause was either a loose muffler or muffler hanger.
Can anyone confirm this and possibly add what their solution was?
Thanks!
Mike
PS: My truck has a completely stock exhaust
Old Nov 23, 2004 | 12:02 AM
moparturd's Avatar
moparturd
Default RE: 04 Hemi rattle at idle under load
If is sounds like "tin" rattling, I'd say a heat shield on the converters, or something of that nature.
Old Nov 23, 2004 | 12:12 AM
mikebol's Avatar
mikebol
Yea, it does kind of... I'll check that too.
Old Nov 23, 2004 | 11:04 AM
moparturd's Avatar
moparturd
Occasionally, mine rattles when I'm at idle, but it hasn't bothered me enough yet to try and figure it out. Let us know if you find it.
Old Nov 24, 2004 | 06:34 PM
Matrix04's Avatar
Matrix04
i had that problem, with mine it was loose pipes, the dealer could not fix it, so i had to take it to a muffler shop, they welded on another hanger and it fixed the problem right away
Old Nov 28, 2004 | 10:45 PM
aberhammer's Avatar
aberhammer
I found a QC truck once where it had a rattle.The cause was a muffler clamp hitting the crossmember.It had apparently been pointing down.I simply turned the clamp 90 degrees and retightened it. Hope this helps.
