need help with tire rim combo
Old Nov 28, 2007 | 12:35 PM
kizer00's Avatar
kizer00
Default need help with tire rim combo
i have a set of Mickey Thompson rims ( 17 - 10 i think)and i need to know if they will fit my 07 QC. the bolt pattern measures right but their not quite fitting in. the tires on the MT's are cooper 315/75-r16 m&5
Old Nov 28, 2007 | 12:43 PM
tdmopar59's Avatar
tdmopar59
Default RE: need help with tire rim combo
the tires are 316/75/16 the rims are 16's and 16 inch rims wont fit on a 3rd gen ram... the smallest is a 17 because of the brake size....
Old Nov 28, 2007 | 12:46 PM
kizer00's Avatar
kizer00
thats what i figured, but my brother said i could grind on the caliber to give it the clearance. i just didn't want to start grinding if it was possibke with out.
Old Nov 28, 2007 | 12:48 PM
kizer00's Avatar
kizer00
what is the correct way to measure the rim size, just so i can make sure? thanks tdmopar59
Old Nov 28, 2007 | 12:49 PM
Tommygunz's Avatar
Tommygunz
it is likely that it is possible to grind some off of the caliper to make them fit, however, the wheel opening is that big for a reason. You really want at least a 17 to cool the brakes, you go smaller than that and less cooling air will get to the calipers pads and rotor and you will end up with a miriad of brake issues. Bottom line, smaler then 17" = unsafe
Old Nov 28, 2007 | 12:53 PM
tdmopar59's Avatar
tdmopar59
yea i wouldnt start grinding away my calipers.... not a good idea... you rims are 16's because the tire tells you that.... just measure directly across....
Old Nov 28, 2007 | 12:55 PM
kizer00's Avatar
kizer00
fom edge of rim to the other edge of rim says 17.
Old Nov 28, 2007 | 12:58 PM
HammerZ71's Avatar
HammerZ71
If you go grinding away on that, you are going to have a very unsafe situation. Sadly, if you are intent on changing out your existing tires and rims, you are going to have to purchase a minimum 17" set. The MT's are very good rims, by the way, I have a set of 17x9 Mickey Thompson Classic II's and love them.
Old Nov 28, 2007 | 12:59 PM
tdmopar59's Avatar
tdmopar59
http://www.moderntiredealer.com/t_in...p;storyID=1190
Old Nov 28, 2007 | 01:03 PM
kizer00's Avatar
kizer00
thanks for all you imput and info on the matter, i really appreciate it.
