7 pin connector questions
Old Dec 2, 2007 | 10:48 PM
ScottJ175's Avatar
ScottJ175
Default 7 pin connector questions
So, what does the 7 pin connector in the tow package get me?
I know one of the 7 pins is for trailer brakes. Is it ready to control those as-is or would a brake controller need to be added?
I think the other two pins are 12V hot, right? Are they ready to go in the trailer tow package?
I only have experience with the 4 pin systems but I might be shopping RVs eventually (3+ years away though gotta pay off the truck first) and want to make sure I fully understand. I searched the forum but couldn't really get a clear picture.
Old Dec 2, 2007 | 11:19 PM
JD1500's Avatar
JD1500
Default RE: 7 pin connector questions
You shoudl get a brake controller for an RV. Cost you about 100 for a good one like a prodigy. They are easy to install.
Your others are hot for the other accesories on the trailer. ousidelights/work lights/charge battery etc. they are good to go.
Old Dec 2, 2007 | 11:40 PM
ScottJ175's Avatar
ScottJ175
ORIGINAL: JD1500
So, as it is the brake circuit is there but doesn't do anything?
Old Dec 2, 2007 | 11:54 PM
JD1500's Avatar
JD1500
Well, if it does, it will be all the brakes, or none of the brakes. Someone else will have to give you specifics. I am not 100% on if it works or not.
In
Old Dec 3, 2007 | 09:47 AM
sddunn2's Avatar
sddunn2
ya u will need a brake controler for sure !! without it i dont think u will have trailer brakes ( could be wrong though ) I installed my brake controler in about 20 min dodge made it super easy just plug ang play
Old Dec 3, 2007 | 11:41 AM
topcop38's Avatar
topcop38
you will not have trailer brakes w/o the controller. the 3 extra wires are- one controls the brakes, one is a constant 12V to run accesories and i think the 3rd is left open for future use but i could be wrong. you really don't need to worry about what they all do, just plug it in and go.
Old Dec 3, 2007 | 12:12 PM
Parts/Service's Avatar
Parts/Service
For the trailer brakes to work, you will have to add a trailer brake controller. Very simple connections. 4 wires to connect, then it plugs in under the dash...
Old Dec 3, 2007 | 12:40 PM
ScottJ175's Avatar
ScottJ175
Thanks for the responses. Won't have to worry about it for awhile but good to know.
