Right Window Switch
Old Dec 6, 2007 | 12:23 PM
kenihemi's Avatar
kenihemi
Default RE: Right Window Switch
Another thought,
Our switches are on a horizontal plane that gets water in them when its raining and the door is open.
Years ago I had a toya truck and they were kinda the same. The mirror angle switch was intermittent and I found that it was corrsion in the contacts. A little cleaning and all was good.
I'd check into that loose connection thing too.
Old Dec 6, 2007 | 02:12 PM
JayH2112's Avatar
JayH2112
I have thesame problem on my '02. My guess is its the lock out switch. It probably goes bad or something. Mine really isn't a big deal to me. I can always roll them down from my side, and I don't mind people having to ask about having their window up or down. My comfort first you know.
Old Dec 6, 2007 | 05:33 PM
herring_jerritt's Avatar
herring_jerritt
who do we talk to about getting a recall on this, cause it seems like all the 03 rams r having this problem
Old Dec 9, 2007 | 09:45 AM
vwomein's Avatar
vwomein
I'd say part/service guy hit it right on. When cars/trucks have a window lockout
switch for the passenger windows, like our trucks have, the power goes through the
driver's door switch, then out to the rest of the windows. The other 3 power window
switches are the same, (in a quad cab)so you can pretty easilyswap with another one.
If the problem is still there, it points to the driver's switch. We sell a lot
of driver's switches at my work for the same problem
Old Dec 9, 2007 | 09:57 AM
sddunn2's Avatar
sddunn2
i had the same problem on my grand charokee and it turned out to be a bad ground in the drivers door panel
Old Dec 9, 2007 | 12:27 PM
suckmyhemi07's Avatar
suckmyhemi07
wow...seems like this is a really popular problemo...victim #9821734596245 i guess here
Old Dec 11, 2007 | 12:01 PM
Ricker's Avatar
Ricker
Me too. '03 1500
Old Jan 21, 2008 | 07:19 PM
jgaff's Avatar
jgaff
I have a 02 2500 that is having a similar problem. I can't roll down the passenger's side window with the drivers side switch? I took both of them loose and tested the circuits. It is getting the signal to the pass. side switch from the driver's side, but must have a problem when going thru the pass. side switch? All of them seem flaky to me? The power locks don't always seem to work right either some times? One thing that I know for a fact is that neither window will work without the driver's side plugged in. I think that I am going to try getting a new pass. side switch and trying that?
Old Jan 22, 2008 | 08:36 PM
Dawiz429's Avatar
Dawiz429
I have already tried your idea. I ordered a switch for the right side. No change. I then removed the driver's side and checked the connections. All good, but no change. After this I discovered that none of the windows will work from their individual switches. I guess the next thing is replace the driver's side. Does anyone have the part number for the driver side module?
Thanks,
Old Jan 23, 2008 | 12:05 AM
Redram05baby's Avatar
Redram05baby
HA!
I Had The Same Problem..
As Parts/Service Said It Was The Drivers Side Switch. Mine Was Under Warranty.
See If My Link Would Be Sticky People Could Find The Solution... uhhhhhummm Moderator.
https://dodgeforum.com/m_1129016/tm.htm
