Right Window Switch
Old Dec 3, 2007 | 11:05 PM
Dawiz's Avatar
Dawiz
Default Right Window Switch
I have a 2002 Dodge Ram 1500 Quad Cab. Occasionally, when I try to use the window switch on the passenger side, it does not work. I can always use the switch on the driver's side. Other times it seems to work fine. I ordered a new switch and installed it on the passenger side, and it does not work.
Any ideas?
Thanks
Dawiz
Old Dec 4, 2007 | 01:10 AM
bagadonutsjd's Avatar
bagadonutsjd
Default RE: Right Window Switch
i've got the same problem only with a '03 dakota quad cab and it's every passenger window switch. they can all be opened from the driver's door switches, but not individually. i'm guessing there's something going on with a fuse, or relay? the problem's intermittent. since the switches are identical (i'm guessing) then there's probably a common problem...any takers?
Old Dec 4, 2007 | 08:24 PM
Parts/Service's Avatar
Parts/Service
The power for the passengers and other window switches goes through the drivers switch first. It sounds like the drivers switch is bad......
Old Dec 4, 2007 | 10:06 PM
herring_jerritt's Avatar
herring_jerritt
i have the same problem on my 03 ram, i would also relay like to know how to fix it
Old Dec 5, 2007 | 11:17 AM
kenihemi's Avatar
kenihemi
There is a window lock button on the driver side that will disable all the other door switches. It is easily hit by mistake and you don't even know it.
Old Dec 5, 2007 | 12:27 PM
bagadonutsjd
already tried the driver's side window lock (first thing i checked as a matter of fact) and the other windows still won't open/close. i'm curious since the power for the other three go through the driver's switch; would not the driver's switch not open/close the driver's side window as well? it's the only switch that works. i don't have access to a schematic so i guess it could be possible but before i purchase an overpriced dealer part i'd like to be sure...
Old Dec 5, 2007 | 01:48 PM
ray97's Avatar
ray97
I have the same problem on my 03 Ram also. [:@]
Old Dec 5, 2007 | 07:17 PM
zman9119's Avatar
zman9119
You can add me to the list too. '03 2500.
Old Dec 5, 2007 | 08:37 PM
MikeHTally's Avatar
MikeHTally
I had a similar issue when I installed my speakers. Turned out I didn't completely seat the driver's side window switches. Apparently, no windows work when the driver's side switches aren't fully connected. Since the problem is intermittent, check the switch module to see if it's a tad loose.
Old Dec 6, 2007 | 12:24 AM
cpukramer's Avatar
cpukramer
I have the exact same problem on my 02 Ram Quad Cab ... its not such a big deal tho ... I havent had a chance to even look in to it yet.
